RME (LMS 3.2) No detect Change Configuration automatically by Syslog Messages
Sep 1st, 2010
I have a problem with the "change audit" for Syslog messages trigger. I set all my devices to send Syslog messages to the CiscoWorks server. When I make any changes to syslog message is sent correctly for the CiscoWorks server, but it does not start automatically collects configuration (config fetch).
Only when I start manually "sync archive" the configuration is stored and detected the change in configuration.
Has not changed anything in config fetch "to" Automated actions Syslog ".
ngoldwat Mon, 09/06/2010 - 06:58
  • Cisco Employee,
You an check RME  > Tools > Syslog > Automated Actions to verify nothing was changed.
Then display 'Config Fetch'. There is contextual help available:
http://:1741/help/rme/fundamentals/index.html?syslog_Defining_Automatd_Actions.html#wp1211314
Nick
