09-01-2010 10:02 AM
Hi everyone,
I'm working on MPLS - (lab) and I was wondering how is it possible (or command) to pass traffic to and from the same AS? In my lab I have to specifiy "nei allow-as in" in order to see routes from routers in my AS. I have 5 routers in my lab - One in AS 777 mpls and the other four in AS 6500). Everything in AS 6500 has the bgp sub command neig "ip addy" allow-as in. This is the only way I can see routes advertised from neighbors.
Thanks in advance.
Solved! Go to Solution.
09-01-2010 10:17 AM
Another (and I believe more used) possibility is to configure as-override on the PE towards CE
router bg MPLS-CORE
address-family ipv6 vrf test
neighbour x.x.x.x as-override
(syntax might be wrong)
Jon
09-01-2010 10:17 AM
router bg MPLS-CORE
Jon
09-01-2010 02:28 PM
Thx Jon, that worked and 5 stars for your answer. Thx.
