09-01-2010 12:54 PM - edited 03-06-2019 12:46 PM
I'm in the process of cleaning up some of the auto QoS configurations at some branch offices....while it was configured on the switchports none of the trunks appeared to have the auto qos voip trust config.
Do I need to enable auto qos on the router inside interface as well or just the switchport connected to it?
If I do need to apply it to the router do I apply it to the interface or the SVI?
Solved! Go to Solution.
09-01-2010 01:56 PM
Only switch module ports on ISR supports "auto qos".
you can't enable auto qos on routed GIG port.
KK.
09-01-2010 01:56 PM
KK.
09-01-2010 01:58 PM
That makes sense, thanks!
