Cisco asa tracker
Sep 1st, 2010
Hello, I was wondering if there is any kind of Cisco tracker , like the Check Point Smartview tracker. I didnt find anything arround the ASDM.
Anyone know about something similar ?.
Thank in advanced
Panos Kampanakis Wed, 09/01/2010 - 15:16
ASDM will let you look at logs, it will let you do captures, it will let you parse and filter logs. But it will not analyze the logs.
Cisco MARS is a comprehensive tool that does that.
I hope it helps.
PK
andresitotubia Thu, 09/02/2010 - 06:45
PK,
Thank you for you reply. I dont think that Cisco Mars is what im looking for.
I dont know if you get the chance to see the smartview of checkpoint product. You can visualize all the connection or filter as you want to (not only for security matters). But the look is very graphic.
I dont think Cisco has something like that. I found a product FirePlotter but is not something.
Panos Kampanakis Thu, 09/02/2010 - 09:32
Yeah, that is true.
Unfortnately ASDM does not yet have a graphic that show connections and their state through the box.
There are other graphics that show top talkers but not on a per connection basis.
PK
