Can't receive calls on 7940
t815093
Hi There,
I'm trying to configure a 7940 as a SIP Client using Vbuzzer SP.
SIP Provider (69.172.204.134) <-----> (99.225.192.171) NAT Router (192.168.0.1) <------> (192.168.0.12) 7940
When I use firmware P0S3-8-2-00, I can get inbound calls, but outbound calls will drop within seconds.
When I use any other firmware (e.g. P0S3-8-12-00), I can NOT get inbound calls, but outbound calls works fine.
I'm using the same files when loading the configs (SIPDefault.cnf and SIP0015F9270D99.cnf), but I could not get both inbound and outbound calls to work on the same firmware. I've telneted to the phone and with debug on, while receiving a call and I could see messages coming in:
Thanks!
t815093
After a bit of troubleshooting (telnet to the phone and debug)... I noticed SIP Messages had @[private address of phone] an not Public IP address of the WAN router. So I've changed:
     nat_address: "99.225.192.171"         ; WAN IP address of NAT box (dotted IP or DNS A record only)
     to
     nat_address: "192.168.0.12"         ;  IP address of 7940 (dotted IP or DNS A record only)
Works perfectly now! Inbound and Outbound calls on P0S3-8-12-00.
Thank you. I just resolved my incoming calls issue on Cisco 7940 which was sending "404 not found" when public IP-ADD was configured in nat_adress. I was scratching my head since a week, even my SIP Provider sonetel.com wasn't able to help.
I have now changed it to Private LAN IP-ADD and now it works like charm.
Thanks a ton.
-ilyas
