errror from c150 box
Sep 1st, 2010
i am getting the following error message from my C150 ironport.
what should i do ?
Subject: Warning <Anti-Virus> ironport.domain.com: Sophos: Error transferringsophos/sophos-4.56/ides.201009010...
Auto forwarded by a Rule
Sophos: Error transferring sophos/sophos-4.56/ides.2010090104.zip: [Errno 54] Connection reset by peer: error reading data
Andreas Mueller Fri, 09/03/2010 - 06:57
Hello Yeow,
looks like a Sophos update did not complete and was interrupted. Maybe a network error, in general no problem as the update will be retried after the specified time interval (5 minutes by default). Check your antivirus status if the patterns are current. If that error occurs more often you'd open a ticket to have this checked.
Andreas
