Can not send the call out by using AS5350XM
Sep 2nd, 2010
Hi Everyone,
I am new to forum.
I got a problem to setup AS5350XM to receive the call from VOIP and then send it out to Vendor or carrier via VOIP too. The call was received but unable to send out, it was an error " OUT OF DESTINATION" I think maybe we need some kind of command to do that. Can anyone know and help please.
Ben
Felipe Garrido Wed, 09/08/2010 - 07:49
Ben,
You'll need to provide a more concise problem description in order for us to help. Where do you see the error mesage? From which call leg does the error message originate from? What VoIP protocol are you using on either call leg?
-Felipe
as5350xmcisco Wed, 09/08/2010 - 17:07
Hi Felipe,
Thank you very much for your reply.
This is the H323 call. I used this command to get the error " show call history voice brief"
error = out of destination
here is my set up for receive the call from customer:
dial-peer voice 8889990 voip
service remote_ip_auth
voice-class codec 1
incoming called-number .T
dtmf-relay rtp-nte
Here is set up for send the call to carrier
dial-peer voice 110002 voip
destination-pattern .T
progress_ind setup enable 3
progress_ind alert enable 1
progress_ind progress enable 1
progress_ind connect enable 1
voice-class codec 1
voice-class h323 1
session target ipv4:203.166.29.165
The first leg it seem working ok because I can see the call land on GW but the GW send the call to carrier that is the problem.
Ben
Felipe Garrido Thu, 09/09/2010 - 08:25
What does the "remote_ip_auth" service do? Is it a custom script? Can you reach "203.166.29.165" from the router?
If possible, collect the following debugs for a failed call.
debug h225 asn1
debug ip tcp transaction
debug voip ccapi inout
Please note the calling and called party numbers.
-Felipe
as5350xmcisco Tue, 09/28/2010 - 21:02
Hi Felipe,
Sorry for late reply.
Here is some ERROR debug:
Disconnect Cause=0
Voice Cause Code =0
Retry Count=0
Ben
Felipe Garrido Thu, 09/30/2010 - 07:20
Hi Ben,
There were no debugs attached to your last post. Also, please upload the full running configuration.
-Felipe
