remote-access VPN on virtual outside IP
Sep 2nd, 2010
It's possible to configure ASA on 8.2.3 release that I have dedicated IP address just for a S2S and RA VPN?
This dedicated IP address is from a pool of outside interface.
Kamil
Jennifer Halim Thu, 09/02/2010 - 04:11
  • Cisco Employee,
No, you can only terminate the VPN on the actual interface IP Address (ie: outside interface ip address), not any virtual ip address.
Nagaraja Thanthry Thu, 09/02/2010 - 05:47
  • Cisco Employee,
VPN endpoint should be an address attached to the port. If you want, you can
dedicate the interface IP for VPN and use other IP's for all of internal
traffic.
Hope this helps.
NT
wkamil123 Thu, 09/02/2010 - 06:04
Yes, it's possible but ASA 5510 has just 4 ethernet ports.
So it's difficult to do this with this number of ports when the failover is run between two ASA also.
Kamil
