Routing Issue
davidjfclawson
We are currently having an issue configuring our wireless interface to allow access to the internet.
We have an Cisco 1841 with two external connections that we have been configuring, with use of a route-map, to direct all traffic except for traffic heading to our remote site over our VPN. We have two internal subnets, one for ethernet connectivity and one for wireless connectivity. The route-map configuration works for our wired connections sending it down one of our external connections for VPN traffic and the other for everything else but when we test a wireless connection it doesn't.
We can see that the wireless connection is getting NAT'd, can resolve DNS but can't connect or ping any website.
Any ideas? I have a feeling it is something very simple.
David.
icmp 72.167.13.44:1      192.168.50.31:1       173.194.37.83:1       173.194.37.83:1
tcp 72.167.13.44:49200   192.168.50.31:49200   192.168.10.203:445    192.168.10.203:445
tcp 72.167.13.44:49490   192.168.50.31:49490   92.122.207.170:80     92.122.207.170:80
tcp 72.167.13.44:49491   192.168.50.31:49491   212.58.246.91:80      212.58.246.91:80
tcp 72.167.13.44:49492   192.168.50.31:49492   212.58.246.99:80      212.58.246.99:80
tcp 72.167.13.44:49493   192.168.50.31:49493   212.58.246.99:80      212.58.246.99:80
tcp 72.167.13.44:49494   192.168.50.31:49494   92.122.207.170:80     92.122.207.170:80
tcp 72.167.13.44:49495   192.168.50.31:49495   212.58.246.99:80      212.58.246.99:80
tcp 72.167.13.44:49496   192.168.50.31:49496   212.58.244.71:80      212.58.244.71:80
tcp 72.167.13.44:49497   192.168.50.31:49497   212.58.246.99:80      212.58.246.99:80
version 12.4
service tcp-keepalives-in
service tcp-keepalives-out
service password-encryption
hostname hatterFW_01
boot-start-marker
boot-end-marker
logging buffered 8192 informational
logging console informational
logging monitor informational
enable password 7
aaa new-model
aaa authentication login userlist local
aaa authentication ppp default local
aaa authorization network groupauthor local
aaa session-id common
resource policy
memory-size iomem 20
clock timezone London 0
clock summer-time London date Mar 30 2003 1:00 Oct 26 2003 2:00
no ip source-route
ip icmp rate-limit unreachable 100
ip icmp rate-limit unreachable DF 1
ip cef
no ip dhcp use vrf connected
ip dhcp excluded-address 192.168.50.254
ip dhcp excluded-address 192.168.50.10 192.168.50.11
ip dhcp pool Wireless
   import all
   network 192.168.50.0 255.255.255.0
   dns-server 192.168.10.1 192.168.10.2
   default-router 192.168.50.254
   lease 3
no ip bootp server
ip domain name hatter.co.uk
ip name-server 192.168.10.1
ip name-server 192.168.10.2
ip ssh time-out 60
ip ssh authentication-retries 2
ip inspect name outbound esmtp
ip inspect name outbound tcp
ip inspect name outbound udp
crypto pki trustpoint TP-self-signed-337632103
enrollment selfsigned
subject-name cn=IOS-Self-Signed-Certificate-337632103
revocation-check none
rsakeypair TP-self-signed-337632103
crypto pki certificate chain TP-self-signed-337632103
certificate self-signed 01
  30820252 308201BB A0030201 02020101 300D0609 2A864886 F70D0101 04050030
  30312E30 2C060355 04031325 494F532D 53656C66 2D536967 6E65642D 43657274
  69666963 6174652D 33333736 33323130 33301E17 0D303930 38313030 39353735
  305A170D 32303031 30313030 30303030 5A303031 2E302C06 03550403 1325494F
  532D5365 6C662D53
  quit
crypto isakmp policy 10
encr aes
authentication pre-share
lifetime 28800
crypto isakmp policy 20
encr 3des
group 2
crypto isakmp key bob address 16.161.13.21
crypto isakmp keepalive 20 10
crypto isakmp xauth timeout 20
crypto isakmp client configuration group VPNCLIENTGROUP
key bob
dns 192.168.10.1 192.168.10.2
domain hatter.co.uk
pool vpn1
acl hattervpn_splitTunnelAcl
crypto isakmp profile VPNclient
   description VPN clients profile
   match identity group VPNCLIENTGROUP
   client authentication list userlist
   isakmp authorization list groupauthor
   client configuration address respond
crypto ipsec transform-set 3des esp-3des esp-sha-hmac
crypto ipsec transform-set ESP-AES-128-SHA esp-aes esp-sha-hmac
crypto ipsec transform-set HiRemote esp-aes esp-sha-hmac
crypto dynamic-map dynmap 20
set transform-set 3des
set isakmp-profile VPNclient
reverse-route
crypto map map1 10 ipsec-isakmp
set peer 16.161.13.21
set transform-set HiRemote
match address 100
crypto map map1 20 ipsec-isakmp dynamic dynmap
bridge irb
interface FastEthernet0/0
description $ETH-WAN$
bandwidth 2048
ip address 242.12.146.210 255.255.255.240
ip access-group outside_acl in
no ip redirects
no ip unreachables
no ip proxy-arp
ip nbar protocol-discovery
ip flow ingress
ip flow egress
ip nat outside
ip inspect outbound in
ip inspect outbound out
ip virtual-reassembly
no ip route-cache cef
ip route-cache flow
ip tcp adjust-mss 1452
no ip mroute-cache
duplex auto
speed auto
no cdp enable
arp timeout 1800
no mop enabled
crypto map map1
interface BVI1
description Wireless LAN
ip address 192.168.50.254 255.255.255.0
ip access-group inside_acl in
ip nat inside
ip policy route-map dialer
interface FastEthernet0/1
description $ETH-LAN$
ip address 192.168.10.254 255.255.255.0
ip flow ingress
ip flow egress
ip nat inside
speed 100
full-duplex
interface ATM0/0/0
no ip address
no ip redirects
no ip unreachables
no ip proxy-arp
ip route-cache flow
no ip mroute-cache
no atm ilmi-keepalive
dsl operating-mode auto
interface ATM0/0/0.1 point-to-point
no ip redirects
no ip unreachables
no ip proxy-arp
no snmp trap link-status
pvc 0/38
  encapsulation aal5mux ppp dialer
  dialer pool-member 1
interface Dot11Radio0/1/0
description Wireless interface
no ip address
no ip redirects
ip local-proxy-arp
broadcast-key vlan 1 change 45
broadcast-key vlan 2 change 45
encryption vlan 1 mode ciphers tkip
encryption vlan 2 mode ciphers tkip
encryption mode ciphers tkip
ssid hatter01
    vlan 1
    authentication open
    authentication key-management wpa
    guest-mode
    wpa-psk ascii 7
speed basic-1.0 basic-2.0 basic-5.5 6.0 9.0 basic-11.0 12.0 18.0 24.0 36.0 48.0 54.0
channel 2452
station-role root
no cdp enable
interface Dot11Radio0/1/0.1
description hatter UnSecure
encapsulation dot1Q 1 native
bridge-group 1
bridge-group 1 subscriber-loop-control
bridge-group 1 spanning-disabled
bridge-group 1 block-unknown-source
no bridge-group 1 source-learning
no bridge-group 1 unicast-flooding
interface Dialer0
bandwidth 8192
ip address 72.167.13.44 255.255.240.0
ip access-group dialer in
ip nat outside
encapsulation ppp
dialer pool 1
dialer-group 1
ppp authentication chap pap callin
ppp chap hostname bob
ppp chap password 7 062A3B7
ppp pap sent-username bob password 7 013F325
interface BVI2
mtu 1514
ip address 192.168.51.254 255.255.255.0
ip nat inside
ip local pool vpn1 192.168.11.1 192.168.11.20
ip route 0.0.0.0 0.0.0.0 242.12.146.209
ip route 146.101.163.30 255.255.255.255 242.12.146.209
ip flow-top-talkers
top 20
sort-by bytes
ip http server
ip http secure-server
ip http timeout-policy idle 60 life 86400 requests 10000
ip nat pool pool1 242.12.146.211 242.12.146.211 netmask 255.255.255.240
ip nat inside source list 111 pool pool1 overload
ip nat inside source route-map dialer interface Dialer0 overload
ip access-list extended hattervpn_splitTunnelAcl
permit ip 192.168.10.0 0.0.0.255 any
ip access-list extended dialer
permit ip 192.168.50.0 0.0.0.255 any
deny   ip any any
ip access-list extended general
permit ip any any
ip access-list extended inside_acl
permit udp host 192.168.10.1 host 172.16.1.78 eq domain
permit udp host 192.168.10.1 host 172.16.1.80 eq domain
permit udp host 192.168.10.2 host 172.16.1.78 eq domain
permit udp host 192.168.10.2 host 172.16.1.80 eq domain
permit tcp host 192.168.10.50 host 172.16.1.90 eq 8080
permit tcp host 192.168.10.50 host 172.16.1.90 eq 8081
permit tcp host 192.168.10.48 host 172.16.1.92 eq 8080
permit tcp host 192.168.10.48 host 172.16.1.92 eq 8081
permit tcp host 192.168.10.63 host 172.16.1.92 eq 8080
permit tcp host 192.168.10.54 host 172.16.1.10 eq 3389
permit tcp host 192.168.10.54 host 172.16.1.11 eq 3389
permit tcp host 192.168.10.54 host 172.16.1.13 eq 3389
permit tcp host 192.168.10.54 host 172.16.1.14 eq 3389
permit tcp host 192.168.10.54 host 172.16.1.15 eq 3389
permit tcp 192.168.10.0 0.0.0.255 host 172.16.1.20 eq 1433
permit tcp 192.168.10.0 0.0.0.255 host 172.16.1.22 eq 1433
permit tcp 192.168.10.0 0.0.0.255 host 172.16.1.24 eq 1433
permit tcp 192.168.10.0 0.0.0.255 host 172.16.1.26 eq 1433
permit tcp 192.168.10.0 0.0.0.255 host 172.16.1.28 eq 1433
permit tcp 192.168.10.0 0.0.0.255 host 172.16.1.30 eq 1433
permit tcp 192.168.10.0 0.0.0.255 host 172.16.1.32 eq 1433
permit tcp 192.168.10.0 0.0.0.255 host 172.16.1.34 eq 1433
permit tcp 192.168.10.0 0.0.0.255 host 172.16.1.36 eq 1433
permit tcp 192.168.10.0 0.0.0.255 host 172.16.1.100 eq 1433
permit tcp 192.168.10.0 0.0.0.255 host 172.16.2.118 eq 1433
permit ip host 192.168.10.50 172.16.0.0 0.0.255.255
permit ip host 192.168.10.51 172.16.0.0 0.0.255.255
permit ip host 192.168.10.57 172.16.0.0 0.0.255.255
permit ip host 192.168.10.66 172.16.0.0 0.0.255.255
permit ip host 192.168.10.61 172.16.0.0 0.0.255.255
permit ip host 192.168.10.67 172.16.0.0 0.0.255.255
permit ip host 192.168.10.83 172.16.0.0 0.0.255.255
permit ip host 192.168.10.84 172.16.0.0 0.0.255.255
permit ip host 192.168.10.55 172.16.0.0 0.0.255.255
permit ip host 192.168.10.160 172.16.0.0 0.0.255.255
permit ip host 192.168.10.163 172.16.0.0 0.0.255.255
permit ip host 192.168.10.203 172.16.0.0 0.0.255.255
permit tcp 192.168.10.0 0.0.0.255 172.16.0.0 0.0.255.255 eq www
permit tcp 192.168.10.0 0.0.0.255 172.16.0.0 0.0.255.255 eq 443
permit tcp 192.168.10.0 0.0.0.255 host 172.16.1.90 eq 7099
permit tcp 192.168.10.0 0.0.0.255 host 172.16.1.93 eq ftp
permit tcp 192.168.10.0 0.0.0.255 host 172.16.1.93 eq 22
deny   ip 192.168.10.0 0.0.0.255 172.16.0.0 0.0.255.255
deny   ip 192.168.11.0 0.0.0.255 172.16.0.0 0.0.255.255
deny   tcp any any eq 4662
deny   tcp any 128.121.20.0 0.0.0.15 eq www
deny   tcp any 128.121.4.0 0.0.0.255 eq www
permit ip any any
permit icmp 192.168.10.0 0.0.0.255 any echo
permit icmp 192.168.10.0 0.0.0.255 any echo-reply
ip access-list extended outside_acl
permit ahp host 146.101.163.30 host 242.12.146.210
permit ahp any host 242.12.146.210
permit esp host 146.101.163.30 host 242.12.146.210
permit esp any host 242.12.146.210
permit udp host 146.101.163.30 host 242.12.146.210 eq isakmp
permit udp any host 242.12.146.210 eq isakmp
permit udp host 146.101.163.30 host 242.12.146.210 eq non500-isakmp
permit udp any host 242.12.146.210 eq non500-isakmp
permit ip 172.16.0.0 0.0.255.255 192.168.0.0 0.0.255.255
permit udp host 146.101.163.30 any eq isakmp
permit udp host 146.101.163.30 eq isakmp any
permit esp host 146.101.163.30 any
permit udp any eq isakmp any
permit udp any any eq non500-isakmp
permit udp any any eq isakmp
permit ahp any any
permit esp any any
permit tcp any host 242.12.146.212 eq 995
permit tcp any host 242.12.146.212 eq 587
permit tcp any host 242.12.146.212 eq www
permit tcp any host 242.12.146.212 eq 443
permit tcp any host 242.12.146.212 eq smtp
permit tcp any host 242.12.146.212 eq 993
permit tcp any host 242.12.146.213 eq www
permit tcp any host 242.12.146.214 eq www
permit tcp any host 242.12.146.215 eq www
permit tcp any host 242.12.146.215 eq 443
permit tcp any host 242.12.146.216 eq www
permit tcp any host 242.12.146.216 eq 443
permit tcp host 80.177.153.32 host 242.12.146.214 eq 8080
permit tcp host 146.101.163.30 host 242.12.146.214 eq 8080
permit icmp any any
deny   ip any any log
no logging trap
logging 192.168.10.203
access-list 1 permit 192.168.10.0 0.0.0.255
access-list 100 permit ip 192.168.0.0 0.0.255.255 172.16.0.0 0.0.255.255
access-list 101 deny   ip 192.168.0.0 0.0.255.255 172.16.0.0 0.0.255.255
access-list 101 permit ip any host 146.101.162.209
access-list 101 permit ip any host 146.101.250.35
access-list 101 permit ip any host 80.64.57.160
access-list 101 permit ip any host 80.64.57.161
access-list 101 permit ip any host 146.101.121.78
access-list 101 permit ip any host 146.101.121.79
access-list 101 deny   ip host 192.168.10.203 any
access-list 101 deny   ip 192.168.10.0 0.0.0.255 172.16.0.0 0.0.255.255
access-list 101 deny   ip 192.168.10.0 0.0.0.255 192.168.11.0 0.0.0.255
access-list 101 deny   ip any 192.168.11.0 0.0.0.255
access-list 101 deny   ip 192.168.10.50 0.0.0.1 any
access-list 101 deny   ip 192.168.10.52 0.0.0.3 any
access-list 101 deny   ip 192.168.10.56 0.0.0.7 any
access-list 101 deny   ip 192.168.10.64 0.0.0.31 any
access-list 101 deny   ip 192.168.10.96 0.0.0.3 any
access-list 101 deny   ip host 192.168.10.100 any
access-list 101 deny   ip host 192.168.10.204 any
access-list 101 deny   ip host 192.168.10.205 any
access-list 101 deny   ip host 192.168.10.206 any
access-list 101 deny   ip host 192.168.10.207 any
access-list 101 deny   ip host 192.168.10.208 any
access-list 101 deny   ip host 192.168.10.209 any
access-list 101 deny   ip host 192.168.10.210 any
access-list 101 deny   ip host 192.168.10.220 any
access-list 101 deny   ip host 192.168.10.221 any
access-list 101 permit ip 192.168.50.0 0.0.0.255 any
access-list 101 permit ip 192.168.10.0 0.0.0.31 any
access-list 101 permit ip 192.168.10.32 0.0.0.15 any
access-list 101 permit ip 192.168.10.48 0.0.0.1 any
access-list 101 permit ip host 192.168.10.101 any
access-list 101 permit ip 192.168.10.102 0.0.0.1 any
access-list 101 permit ip 192.168.10.104 0.0.0.7 any
access-list 101 permit ip 192.168.10.112 0.0.0.15 any
access-list 101 permit ip 192.168.10.128 0.0.0.63 any
access-list 101 permit ip 192.168.10.192 0.0.0.31 any
access-list 101 permit ip 192.168.10.224 0.0.0.15 any
access-list 101 permit ip 192.168.10.240 0.0.0.7 any
access-list 101 permit ip 192.168.10.248 0.0.0.3 any
access-list 101 permit ip 192.168.10.252 0.0.0.1 any
access-list 102 permit ip any any
access-list 103 deny   ip any any dscp 1 log
access-list 103 permit ip any any
access-list 104 deny   ip 192.168.0.0 0.0.255.255 172.16.0.0 0.0.255.255
access-list 104 deny   ip host 192.168.10.203 172.16.0.0 0.0.255.255
access-list 104 deny   ip host 192.168.10.203 192.168.11.0 0.0.0.255
access-list 104 deny   ip any 192.168.11.0 0.0.0.255
access-list 104 permit ip host 192.168.10.203 any
access-list 104 permit ip host 192.168.10.204 any
access-list 104 permit ip host 192.168.10.205 any
access-list 104 permit ip host 192.168.10.206 any
access-list 104 permit ip host 192.168.10.207 any
access-list 104 permit ip host 192.168.10.208 any
access-list 104 permit ip host 192.168.10.209 any
access-list 104 permit ip host 192.168.10.210 any
access-list 104 permit ip host 192.168.10.220 any
access-list 104 permit ip host 192.168.10.221 any
access-list 105 deny   ip 192.168.0.0 0.0.255.255 172.16.0.0 0.0.255.255
access-list 105 deny   ip host 192.168.10.203 any
access-list 105 deny   ip 192.168.10.0 0.0.0.255 172.16.0.0 0.0.255.255
access-list 105 deny   ip 192.168.10.0 0.0.0.255 192.168.11.0 0.0.0.255
access-list 105 deny   ip any 192.168.11.0 0.0.0.255
access-list 105 deny   ip 192.168.10.0 0.0.0.31 any
access-list 105 deny   ip 192.168.10.32 0.0.0.15 any
access-list 105 deny   ip 192.168.10.48 0.0.0.1 any
access-list 105 deny   ip host 192.168.10.101 any
access-list 105 deny   ip 192.168.10.102 0.0.0.1 any
access-list 105 deny   ip 192.168.10.104 0.0.0.7 any
access-list 105 deny   ip 192.168.10.112 0.0.0.15 any
access-list 105 deny   ip 192.168.10.128 0.0.0.63 any
access-list 105 deny   ip 192.168.10.192 0.0.0.31 any
access-list 105 deny   ip 192.168.10.224 0.0.0.15 any
access-list 105 deny   ip 192.168.10.240 0.0.0.7 any
access-list 105 deny   ip 192.168.10.248 0.0.0.3 any
access-list 105 deny   ip 192.168.10.252 0.0.0.1 any
access-list 105 deny   ip host 192.168.10.204 any
access-list 105 deny   ip host 192.168.10.205 any
access-list 105 deny   ip host 192.168.10.206 any
access-list 105 deny   ip host 192.168.10.207 any
access-list 105 deny   ip host 192.168.10.208 any
access-list 105 deny   ip host 192.168.10.209 any
access-list 105 deny   ip host 192.168.10.210 any
access-list 105 deny   ip host 192.168.10.220 any
access-list 105 deny   ip host 192.168.10.221 any
access-list 105 permit ip 192.168.10.50 0.0.0.1 any
access-list 105 permit ip 192.168.10.52 0.0.0.3 any
access-list 105 permit ip 192.168.10.56 0.0.0.7 any
access-list 105 permit ip 192.168.10.64 0.0.0.31 any
access-list 105 permit ip 192.168.10.96 0.0.0.3 any
access-list 105 permit ip host 192.168.10.100 any
access-list 105 permit ip 192.168.50.0 0.0.0.255 any
access-list 106 permit ip any any
access-list 107 permit ip any any
access-list 109 permit ip 0.0.0.0 255.255.0.0 0.0.0.0 255.255.0.0
access-list 109 permit ip 0.0.0.0 255.255.0.0 0.0.0.0 255.255.255.0
access-list 109 permit ip any 0.0.0.0 255.255.255.0
access-list 109 permit ip 0.0.0.0 255.255.255.0 0.0.0.0 255.255.255.0
access-list 110 deny   ip 192.168.10.0 0.0.0.255 172.16.0.0 0.0.255.255
access-list 110 deny   ip 192.168.10.0 0.0.0.255 192.168.11.0 0.0.0.255
access-list 110 deny   udp host 192.168.50.31 192.168.10.0 0.0.0.255 eq domain
access-list 110 permit ip host 192.168.10.51 any
access-list 110 permit ip host 192.168.10.52 any
access-list 110 permit ip host 192.168.10.55 any
access-list 110 permit ip host 192.168.10.56 any
access-list 110 permit ip host 192.168.10.57 any
access-list 110 permit ip host 192.168.10.61 any
access-list 110 permit ip host 192.168.10.66 any
access-list 110 permit ip host 192.168.10.68 any
access-list 110 permit ip host 192.168.10.76 any
access-list 110 permit ip host 192.168.10.83 any
access-list 110 permit ip host 192.168.10.84 any
access-list 110 permit ip host 192.168.50.31 any
access-list 110 deny ip any any
access-list 111 deny   ip 192.168.10.0 0.0.0.255 172.16.0.0 0.0.255.255
access-list 111 deny   ip 192.168.10.0 0.0.0.255 192.168.11.0 0.0.0.255
access-list 111 deny   ip any 192.168.11.0 0.0.0.255
access-list 111 deny   ip host 192.168.10.51 any
access-list 111 deny   ip host 192.168.10.52 any
access-list 111 deny   ip host 192.168.10.55 any
access-list 111 deny   ip host 192.168.10.56 any
access-list 111 deny   ip host 192.168.10.57 any
access-list 111 deny   ip host 192.168.10.61 any
access-list 111 deny   ip host 192.168.10.66 any
access-list 111 deny   ip host 192.168.10.68 any
access-list 111 deny   ip host 192.168.10.76 any
access-list 111 deny   ip host 192.168.10.83 any
access-list 111 deny   ip host 192.168.10.84 any
access-list 111 deny   ip host 192.168.50.31 any
access-list 111 permit ip 192.168.50.0 0.0.0.255 any
access-list 111 permit ip 192.168.10.0 0.0.0.255 any
dialer-list 1 protocol ip permit
snmp-server community bob RO
snmp-server host 192.168.10.203 bob
arp 192.168.10.110 03bf.c0a8.0a6e ARPA
arp 192.168.10.111 03bf.c0a8.0a6e ARPA
route-map dialer permit 20
match ip address 110
set interface Dialer0
control-plane
bridge 1 protocol ieee
bridge 1 route ip
scheduler allocate 20000 1000
end
Hi David,
Removing the ACL from the BVI interface probably won't help here: it is placed in the inbound direction which is basically the traffic going from the wireless clients and entering the routed part of the router. You may give it a try but I would not expect too much. You have stated yourself that the NAT entries are populated correctly, so from this it follows that either the packets from the wireless clients are unable to go out to the internet, or the replies cannot make it back. Follow the path in both directions and have a look on those appropriate ACLs.
Eventually, you could add a single deny ip any any log at the very end of each ACL, one at a time, and see if there are any dropped packets logged that constitute the traffic from your wireless clients going out, or responses coming back in.
Best regards,
Peter
8 Replies 8
Peter Paluch
David,
You have a fairly large ACL and IP Inspect configuration which is quite hard to follow here. I suggest trying to temporarily remove the ACLs and IP Inspect away from the interfaces and putting them subsequently back, one by one, to see whether the traffic is actually blocked by those ACLs and which one exactly is the one blocking your traffic.
If removing the ACLs does not help then let's try looking down further on the NAT and routing process.
Best regards,
Peter
Hi Peter,
Yes, the ACL is large, and I suspect a lot of the ACLs are not needed but at the moment I don't think I'll be able to touch many of them. Are there any in specific that are worth looking at removing? Would it be worth removing the ACL inside_acl on the wireless interface BVI1?
David.
Hi David,
Best regards,
Peter
Ok, thanks for the suggestions, I will give the logging a go.
Just I'm not missing anything, I've removed the ACL from BVI1 because the rules didn't even match the traffic so it was pointless IMO, so that leaves the following location that the problem can exist, the ACL applied to Dialer0 Inbound? There are no outbound ACLs applied to either Dialer0 or BVI1 so the traffic should not be blocked?
David.
David
Just to clarify, is the wireless client you are testing from 192.168.50.31 ? because that is the only wireless IP address you have in your 110 acl which is used in the route-map.
Jon
Hi Jon,
Yeah, for the moment that is the only client I want to apply the new route to, basically for testing.
David.
So what does a traceroute show ie. how far does it get. Can you run a traceroute for both wired and wireless client.
Jon
Hey guys,
So it was because we had the ACL dialer configured to access the internal addresses, but we should have had the rule configured to allow access to the NAT'd addresses.
Pete, the ACL log idea worked a charm.
Thanks for both your input,
David.
