How to config an IP address to a port in switch 4507R-E
Sep 2nd, 2010
I m very new to networking line. I have Cisco 4507R-E as core switch and i have connected to the console to do my intial setup. I have 1 24 port module at 1st slot. I would like to know how to config a IP address to the port? . I have 2 Cisco IP Phone connected to the switch. Need to set the IP for these two IP Phone and need to ping and try the connection. I need it very urgently.Thanks in advance
Jon Marshall Thu, 09/02/2010 - 03:09
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
With a L3 switch you don't actually assign IP's to ports usually. What you do is to create a vlan and then assign the phones into that vlan so assuming your subnet for the vlan is 192.168.5.0/24
4500(config)# vlan 10
4500(config)# int vlan 10
4500(config-if)# ip address 192.168.5.1 255.255.255.0
4500(config)# no shut
then on the 2 ports for the ip phones -
int gi0/1
switchport
switchport mode access
switchport access vlan 10
spanning-tree portfast
then you allocate an IP address of the 192.168.5.0/24 network to each phone.
Jon
ssnickson Thu, 09/02/2010 - 23:28
Hi marshall,
THanks for your reply. I have tried the command you have advice
i can set the vlan but when i try to set the ip address for a particular port. I doest allow me to enter 0/1. it always says  % Invalid input detected at marker
and the marker is at 0. What could be the possible error
vragotha Thu, 09/02/2010 - 23:37
  • Silver, 250 points or more
If the module is in slot 1, then try interface gig/fast 1/?
If the port is L2, then you cannot assign an IP address. Like  Jon mentioned, assign the port to a VLAN
ssnickson Thu, 09/02/2010 - 23:59
For
"If the module is in slot 1, then try interface gig/fast 1/?
If the port is L2, then you cannot assign an IP address. Like  Jon mentioned, assign the port to a VLAN"
The module is actually in slot 1
i tried using gi0/1 and fast0/1 but it still gives me the same error
when i try help with ?
under gi ?
it only show <1-7>
vragotha Fri, 09/03/2010 - 00:00
Use 1/0 1/1 etc, not 0/0 or 0/1
Jon Marshall Thu, 09/02/2010 - 23:42
  • Hall of Fame,
    Founding Member
    2017 LAN, WAN
ssnickson wrote:
Hi marshall,
Why are you trying to assign an IP to the port ??
Assign an IP to the vlan interface as described and then assign IPs to the phones. If you assign an IP to the port this will not mean that the IP phone has that IP. You need to configure the actual phone with an IP or setup DHCP.
Jon
ssnickson Fri, 09/03/2010 - 00:06
Hi Marshall,
Meaning to say that ip phone IP address has to be within the VLAN IP range ?
ok my IP Phone Address are
10.10.12.3 and 10.10.12.2 (Default when we connect)
I set the VLAN as 10.10.12.0
So do i need to do anything on the IP Phone ?
or need to do setting in the switch?
Jon Marshall Fri, 09/03/2010 - 00:35
  • Hall of Fame,
    Founding Member
    2017 LAN, WAN
ssnickson wrote:
Hi Marshall,
You don't need to config anything on a switch. You need to either config the phone itself to have a static IP or you need to seup DHCP so the phone can get an address. The phone should have interface that allows you to set the IP or tell it to use DHCP.
Jon
