Redundant Supervisor Engine 720-3B reloads
Answered Question
Sep 2nd, 2010
Hello everybody.
There is a Cisco Catalyst 6513 in my office. Recently we decided to setup redundant Supervisor Engine 720-3B. When we did it, its became STANDBY COLD, and then it reloads. IOS is equal on both supervisors. It must be STANDBY HOT (SSO) redundancy. Any ideas about it? There is a configuration and show ver and show module outputs, and log of my actions.
Thanks for help!
Best regards, Takush Roman.
Correct Answer by Reza Sharifi about 6 years 10 months ago
Hi Roman,
Please follow below document to deploy SSO mode on your Sups.
Also, looking at the version of code you are running, it is pretty old.  You may want to upgrade to a newer version i.e SXI2a or SXI4a and test again.
http://www.cisco.com/en/US/docs/switches/lan/catalyst6500/ios/12.2SX/configuration/guide/nsfsso.html#wp1119694
Reza
Overall Rating: 5 (1 ratings)
Correct Answer
Reza Sharifi Thu, 09/02/2010 - 11:11
  • Cisco Designated VIP,
    2017 LAN
Hi Roman,
Reza
Roman Takush Thu, 09/02/2010 - 23:57
Thanks Reza!
Think i did everything right as it wrote in this document. And there is a strange thing : on the other 6500 chassis my supervisors makes redundancy without any problems. With the same IOS, but without any installed modules and without my startup-configuration. So i think there is a problem either in modules or in configuration.
Best regards,
Roman Takush.
Roman Takush Mon, 01/07/2013 - 14:58
Sorry, forgot to reply.=] after IOS upgrade everything become fine. Think it's some kind of a bug.
