Traceroute with EEM to multiple addresses
Sep 2nd, 2010
    I am looking for a way to traceroute to a number of ip addresses(about 50) all at the same time. For example, every 2 hours I want to do a traceroute from a router to remote locations to confirm traffic is routing across the correct WAN circuit. Does anyone have any scripts for this or provide any guidance?
Joe Clarke Thu, 09/02/2010 - 22:13
This script doesn't sound too difficult on the surface.  You would use a watchdog timer ED to trigger every two hours.  The question is, do you really want to trace to 50 addresses in parallel, or can the script trace to each in series?  What do you want to do with the output?
At the simplest, this script will perform a traceroute to a host specified in the traceroute_host EEM environment variable.  The output will be sent via a syslog message.
::cisco::eem::event_register_timer watchdog time 7200
if { ! [info exists traceroute_host] } {
    action_syslog msg "ERROR: Cannot execute: environment variable traceroute_host has not been set"
    exit 1
namespace import ::cisco::eem::*
namespace import ::cisco::lib::*
proc run_cli { clist } {
    set rbuf ""
    if {[llength $clist] < 1} {
        return -code ok $rbuf
    if {[catch {cli_open} result]} {
        return -code error $result
    } else {
        array set cliarr $result
    if {[catch {cli_exec $cliarr(fd) "enable"} result]} {
    if {[catch {cli_exec $cliarr(fd) "term length 0"} result]} {
    foreach cmd $clist {
        if {[catch {cli_exec $cliarr(fd) $cmd} result]} {
        append rbuf $result
    if {[catch {cli_close $cliarr(fd) $cliarr(tty_id)} result]} {
        puts "WARNING: $result"
set output [run_cli "traceroute $traceroute_host"]
action_syslog msg "$output"
mruhenkamp Fri, 09/03/2010 - 04:12
Thanks for the response.
If I could do 10 addresses every 5 or 10 minutes, that would be fine too. So if the script does it's traceroutes in a series, that's OK.
When I do a trace, I am looking for a particular address in one of the hops. I am looking for 172.27.x.x in the hops. If I see this IP range in one of the hops, I know routing is working properly. If I don't see 172.27.x.x in the hops, I want it to generate an email to me indicating the IP address that the traceroute was incorrect for.
I hope this helps explain it in more detail.
Thanks for the assistance.
mruhenkamp Fri, 09/03/2010 - 11:31
One other thing, I would like to accomplish this by IOS CLI applets instead of .tcl scripts. Any help you can provide is appreciated.
Joe Clarke Sun, 09/05/2010 - 00:34
What version of code are you running?  You will not be able to do what you want with applets unless you have EEM 3.0 or higher.
Joe Clarke Tue, 09/07/2010 - 21:31
Since you have EEM 3.0, then you can use an applet.  Here is an example for one address.  You can adapt this to add multiple destinations.
event manager applet periodic-traceroute
event timer watchdog time 7200
action 001 cli command "enable"
action 002 cli command "traceroute x.x.x.x"
action 003 regexp "(172\.27\.[0-9]+\.[0-9]+")" $_cli_result ignore match
action 004 if $_regexp_result eq 1
action 005 mail subject "Address found in traceroute to x.x.x.x" body "Found $match in traceroute to x.x.x.x" to [email protected] from [email protected] server y.y.y.y
action 006 end
Here, x.x.x.x is the address to which you are tracerouting, y.y.y.y is the IP address of your SMTP server, and [email protected] is the address for your emails.
mruhenkamp Wed, 09/08/2010 - 08:22
Thanks for the information. I have added multiple trace destinations but when it finds a match to send an email, after it sends the email, it throws me out of the applet and doesn't finish the remaining code. How do I force it to go all the way thru to code regardless of whether it finds a result eq 0 or not?
Attached is some code I have.
Joe Clarke Thu, 09/09/2010 - 23:40
Result eq 0 means a match was not found.  But even if a match is not found, the applet should continue to run.  One bit of caution is that the maximum run time of this appet is 20 seconds.  That may not nearly enough time to run through all addresses.  Try extending that time to 100 seconds in the event declaration:
event timer watchdog time 100 maxrun 100
Related Content
