IOS as a simple web server
Sep 2nd, 2010
Dear Community!
I would like to use a Cisco router as simple web-server hosting an automatic proxy configuration script file. Is is possible to configure HTTP AAA to allow access without username / password authentication?
See the test configuration below:
aaa new-model
aaa authentication login CISCO_HTTP_AUTH none
aaa authorization exec CISCO_HTTP_AUTH none
aaa authorization commands 15 CISCO_HTTP_AUTH none
access-list 99 permit host [***Host IP***]
ip http server
ip http access-class 99
ip http authentication aaa login-authentication CISCO_HTTP_AUTH
ip http authentication aaa exec-authorization CISCO_HTTP_AUTH
ip http authentication aaa command-authorization 15 CISCO_HTTP_AUTH
no ip http secure-server
ip http path flash:
Router#dir
Directory of flash:/
    1  -rw-    22855564                    <no date>  [*** IOS Image ***]
     2  -rw-        3877   Sep 2 2010 13:15:09 +02:00  ipproxy
33030140 bytes total (10170568 bytes free)
Router#
Thanks in advance!
Belabacsi
Javier Henderson Thu, 09/02/2010 - 09:50
  • Cisco Employee,
Define an authentication method using "none" then apply it to the http authentication configuration.
e.g.
aaa authentication login example none
ip http authentication aaa login-authentication example
Please be aware of the security implications of this.
Related Content
