Third Party Billing Server
Sep 2nd, 2010
Hello All
We have call manager 7.0.1 and a billing server which gets calling informations and shows it in a web format.I have a problem sending informations to that server,from which part of the call manager i force to send information to my billing server ? Or is it a problem abaut my database on call manager.How can i fix that ?
Thank you very much...
Overall Rating: 4 (1 ratings)
Jaime Valencia Thu, 09/02/2010 - 07:46
  • Cisco Employee,
  • Hall of Fame,
    2011
You configure CUCM to send the info here:
Configuring CDR Repository Manager
Without knowing how your 3rd party billing works no one can tell you if the problem is with the DB or not.
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
dark326758 Fri, 09/03/2010 - 02:10
Thank you for your answer,as i searched my billing server uses FTP
( File Zİlla )  to get call information.While using FTP server gives that error
(000009) 9/3/2010 12:01:13 PM - ab (10.*.*.*)> STOR \cdr_StandAloneCluster_01_201008081356_35490
(000009) 9/3/2010 12:01:13 PM - ab (10.*.*.*)> 550 Permission denied
How can i give permission ?
