QM 2.7.3 evaluation form
Sep 2nd, 2010
/* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-priority:99; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:11.0pt; font-family:"Calibri","sans-serif"; mso-ascii-font-family:Calibri; mso-ascii-theme-font:minor-latin; mso-hansi-font-family:Calibri; mso-hansi-theme-font:minor-latin; mso-bidi-font-family:"Times New Roman"; mso-bidi-theme-font:minor-bidi;}
Our customer has multiple evaluation questions on a legacy form and we are moving them to QM.  It seems as if the QM system will only allow a single type of evaluation question on a form; 1-5 or Y/N.
  • Can we add an evaluation tab with Y/N evaluation questions to an evaluation form that already has several 1-5 grading tabs configured?
  • If not, can we create a second form with the Y/N evaluation questions that an evaluator can switch to and pull up easily in the same session?
  • Can the 1-5 evaluation measurement be modified to a 1/2/3 measurement and, can the numbers at the top be modified to read Poor/Meets/Exceeds?
thanks
-Sam
lohjintiam Tue, 09/14/2010 - 04:07
Hi Sam,
Unfortunately the answer to all your questions are no, no and no
The following can be done in v8.0 which might address some of the issues
a) ability to use both Y/N and 0-5 in the same evaluation form
b) ability to use different evaluation forms for a particular call
c) each section is not limited to 10 questions but the entire form is limited to 100 questions (my condolences to the evaluator)
Thanks!
-JT-
Related Content
