CiscoWorks:Archieve configurations of routers/switches with only ssh/telnet
Answered Question
Sep 2nd, 2010
I want to do the archieve configurations of couple of routers/switches with only ssh/telnet and rest thousands of devices will be via snmp.
Currently I am backing up the configurations of thoudands of  routers/switches via snmp, as snmp is configured on them, but couple of routers/switches are external and snmp is not configured on them so I want to get their configuration via ssh/telnet only.
Please advise me that is it possible to do the archieve configurations of routers/switches with only ssh/telnet?
I am using the
LMS: 1.2.0
RME: 4.3.0
CS:    3.3.0
CM:   5.2.1
DFM: 3.2.0
Correct Answer by Joe Clarke about 6 years 7 months ago
The config archive protocol order applies to all devices universally.  Since you are using TFTP for most of your devices, I recommend you leave TFTP at the top of the protocol order list.  Add TELNET and SSH below TFTP.  The external devices will be attempted with SNMP/TFTP, but those operations will fail.  RME will then fall back to TELNET then to SSH.  It will eventually fetch the configuration successfully.
Overall Rating: 5 (1 ratings)
Correct Answer
Joe Clarke Thu, 09/02/2010 - 23:46
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
