Replacing 6500 VSS with Nexus 7K
Sep 2nd, 2010
A basic overview of our current network design for core and distribution is as follows:
Core:
6506-E chassis in VSS
Distribution:
6509-E chassis single sup connected to each of the 6506 chassis in the core.
We are looking to replace the VSS in the core with Nexus 7K switches.  Since the Nexus switches are not virtual by nature, I have to consider a HA protocol like HSRP or GLBP.  Currently our links between the Core and Dist are L3 Point-To-Point.  We wish to maintain this configuration in the new design.  Since the two links on the Dist side are port-channels we currently have 2Gbps throughput.  If I use HSRP with LACP one link goes into suspended mode, therefore only giving us 1Gbps throughput.  With GLBP we continue to have 2Gbps.  From what I can tell, ECMP (Equal-cost multipath) is enabled and should be in effect at this point, but I cannot find a way to prove this since I do not have another 6509 for distribution (my test distribution switch is just a 3560).
My question is this...
What is the best practice way to go in this situation? Should we allow STP to provide a look free environment and use priorities to determine the path (using HSRP and LACP) or should I use GLBP and have an active-active scenario from DIST to Core?  Any suggestions on a solid way to test that load balancing is in fact working properly?
Excuse me if I misspeak on anything here as this is my first solo attempt at replacing a core.  I've been living in the distribution and access layers for many years now.
Thank you in advance for any and all feedback.
Brian
Jon Marshall Thu, 09/02/2010 - 07:59
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
The Nexus switches do support VPC (Virtual port channel - think of MEC on VSS) and VDC (virtual switches within the same chassis). Also HSRP has been modified on the Nexus 7K switches so that in effect your pair of Nexus switches become active/active in HSRP terms. It might be worth you having a read of some of the Nexus white papers which specifically cover Nexus/6500 intergration -
Nexus whitepapers.
Definitely have a read of the last white paper in the list about VPC and HSRP interaction.
Jon
beausoleilb1 Thu, 09/02/2010 - 08:51
I do have a VDC running with a vPC link between them for the Core switches.  I guess I failed to mention that in the post... I tried to provide as much detail as I could.  When I configure HSRP according to the guides, it recommends ACTIVE mode for the interfaces in the port-channel rather than ON mode, which then enabled LACP on the interfaces, which in turn suspends one of the interfaces in the channel, thus creating an active-standby scenario.  With GLBP the guides recommends ON mode for the interfaces in the port-channel which then disables LACP, thus creating an active-active scenario.  I have read many docs and papers, and searched the web for best practices sample configs, but since the Nexus is a fairly new product, i'm sure there is a limited amount of information out there yet.  I will also continue to investigate.
Thanks for your reply.
Chad Peterson Thu, 09/02/2010 - 11:19
  • Cisco Employee,
When using LACP you shouldn't get into an active/standby scenerio.  There is something wrong here.
Can you send some output to show whats going on?  What is attached to each link...how is it connected etc.
beausoleilb1 Fri, 09/03/2010 - 12:04
Chad-
A quick overview of the topology for this lab/prep setup:
Two Nexus 7010 switches with a VDC named Core and vPC between them.  Our normal distribution switch is a 6509 but since I do not have a spare I am trying to make do with a spare 3560 running the latest IOS.  From the 3560 I have a L3 1Gb link to each of the N7K switches in a port channel.  The default route is the GLBP address of this port channel, and OSPF is the routing protocol.  I'm not sure how to tell which side of the link is placing the interface in Suspended mode.  Hope some of the outputs below provide some details and a path.
What I am trying to accomplish is replacing the 6500 VSS in the core with the Nexus 7K switches while keeping the L3 portchannels i currently have in place from the distribution to the core, hopefully providing a load balance scenario.
N7K1-Core# show run int po51
interface port-channel51
  no ip redirects
  ip address 10.95.254.42/29
  ip router ospf 51 area 0.0.0.0
  glbp 51
    ip 10.95.254.41
N2K1-Core# show run int po51
  ip address 10.95.254.43/29
  glbp 51
    ip 10.95.254.41
ENPBX3-Lab#show run int po2
interface Port-channel2
no switchport
ip address 10.95.254.44 255.255.255.248
N7K1-Core# show port-channel summary | i 51
51    Po51(RD)    Eth      LACP      Eth3/3(s)
N7K2-Core# show port-channel summary | i 51
51    Po51(RU)    Eth      LACP      Eth3/3(P)
DIST-Test# show etherchannel summary | i Po2
2      Po2(RU)         LACP      Gi0/1(s)    Gi0/2(P)
DIST-Test#show etherchannel detail
Group: 2
Group state = L3
Ports: 2   Maxports = 16
Port-channels: 1 Max Port-channels = 16
Protocol:   LACP
Minimum Links: 0
Ports in the group:
Port: Gi0/1
Port state    = Up Cnt-bndl Suspend Mstr Not-in-Bndl
Channel group = 2           Mode = Active          Gcchange = -
Port-channel  = null        GC   =   -             Pseudo port-channel = Po2
Port index    = 0           Load = 0x00            Protocol =   LACP
Flags:  S - Device is sending Slow LACPDUs   F - Device is sending fast LACPDUs.
        A - Device is in active mode.        P - Device is in passive mode.
Local information:
                            LACP port     Admin     Oper    Port        Port
Port      Flags   State     Priority      Key       Key     Number      State
Gi0/1     SA      susp      32768         0x2       0x2     0x1D1       0x5
Partner's information:
Port      Flags   Priority  Dev ID          Age    key    Key    Number  State
Gi0/1     FA      32768     a8b1.d457.3142   7s    0x0    0x32   0x303   0xF
Age of the port in the current state: 0d:00h:42m:45s
Port: Gi0/2
Port state    = Up Mstr Assoc In-Bndl
Port-channel  = Po2         GC   =   -             Pseudo port-channel = Po2
Local information:
Gi0/2     SA      bndl      32768         0x2       0x2     0x1D2       0x3D
Gi0/2     SA      32768     18ef.63e4.6dc2  29s    0x0    0x32   0x303   0x3D
Age of the port in the current state: 0d:00h:29m:24s
Port-channels in the group:
Port-channel: Po2    (Primary Aggregator)
Age of the Port-channel   = 2d:00h:24m:11s
--More-- 2010 Sep  4 00:49:25 N7K2-Core %$ VDC-2 %$ %ARP-2-DUP_SRC_IP:  arp [4119]  Source address of packet received from a8b1.d457.3142 on Vlan10(port-channel200) is duplicate of local, 10.95.254.198
Logical slot/port   = 2/2          Number of ports = 1
HotStandBy port = null
Passive port list   = Gi0/1 Gi0/2
Port state          = Port-channel L3-Ag Ag-Inuse
Protocol            =   LACP
Port security       = Disabled
Ports in the Port-channel:
Index   Load   Port     EC state        No of bits
  0     00     Gi0/2    Active             0
Time since last port bundled:    0d:00h:29m:30s    Gi0/2
Time since last port Un-bundled: 0d:00h:29m:41s    Gi0/2
Thanks for taking a look.
-Brian
drussell Mon, 03/12/2012 - 19:17
Did you find out what caused the problem?  I had something similar, also with a 3560 and Nexus VPC.
gnijs Fri, 05/18/2012 - 04:53
  • Bronze, 100 points or more
Just my 2 cents: i think this is because you created a routed portchannel. Just create a trunked portchannel with VLAN 51 for example (switchport trunk allowed vlan 51). then put ip config on "int vlan 51".
The portchannel to the acess should come up with P/P (both links present)
Related Content
