3560X Console & Power Cables
Answered Question
Sep 2nd, 2010
Allright,
So we just ordered 4 of the 3560X Switches. Like a kid on Christmas morning, I opened the box and found a couple of new things....
1. There is a mini usb port on the front that says "console" on it. Looks like Cisco is moving away from the RJ45 Com port connector. Cool. However, is there is a certain cable that I need or do I just use any USB cable that will fit? What kind of software would I use with this? I don't think putty can point to a usb cable.
2. It looks like Cisco is using a proprietary Power cable now. Is to keep people from using cheap power cables?
Ben
Correct Answer by Jerry Ye about 6 years 4 months ago
Just any USB Type-B cable (the USB console is in the front). The USB driver software is available from Cisco.com 3560X software download.
For power cable, are you talking about the power supplies on the rights (when you are looking at it from the back)? They are the standard power cables. The power cables in the middle of the chassis are the stack power cable. You can read more about the stack power from the following link.
http://www.cisco.com/en/US/prod/collateral/switches/ps5718/ps6406/data_sheet_c78-584733.html
HTH,
jerry
Overall Rating: 5 (1 ratings)
Correct Answer
Jerry Ye Thu, 09/02/2010 - 08:27
HTH,
jerry
