First Data communication slow
arummer
i have a problem with a data transfer between a Windows client and a NetApp across two WAAS systems.
However this problem happens only in one direction and only for first-time transmission of a file.
But this first (optimized) transmission takes much longer than if the data are not optimized (without Waas transmission systems on the same connection)
Here is an example, transfer of a 2.3 mb pdf document.
This problem is understandable with different file sizes
WAAS mit Cifs,TFO,DRE,LZ
1.       Time     HQ – Branch      1min 36sec
2.       Time     HQ – Branch      2 sec
3.       Time     Branch –HQ       2 sec
Without Wan Optimazation
HQ – Branch      6 sec
Branch –HQ       6 sec
Does anyone have an idea how to fix this problem
Bhavin Yadav
You may want to verify following things in the WAAS network.
1. Duplex
2. Fragmentation - try lowering MTU and MSS on router or WAAS, depending upon originator / recipient of packets.
3. Connection status: is it showing same TDL / TCDL during both operations.
4. How is the reverse copy operation? is that working as expected?
5. WCCP parameters, esp. if you are using GRE as it will add up to overhead on the packet size overall.
6. Any disk issues on any of the WAEs (Client / server side)
7. Is this issue limited to these two sites or it is overall across all the sites?
8. show alarms on both WAEs to check if there is any alarm.
9. type-tail syslog.txt 200 and verify the logs. do you see any eye-catching error message popping up repeatedly during this file transfer or otherwise?
Depending upon above details, we may have to open other aspects to this issue.
Hope this helps,
Regards.
now I have gathered the necessary informations.
1. Duplex
All Interfaces Full Duplex
MSS changed for the complete device group from 1432 to 1300 bytes, but the problem remains.
Copy Operation of 3,5 MB PDF – from NetApp to Client 3 min
Client Side:
WAAS-03#sh statistics connection | include 172.16.189.16
   428     10.2.18.205:62808     172.16.189.16:445 00:21:5e:75:91:d4 TCDL  47.1%
NetApp Side:
WAAS01-ACC#sh statistics connection  | include 172.16.189.16
    48     10.2.18.205:62808     172.16.189.16:445 00:21:5e:75:cb:f0 TCDL  40.1%4.
4.How is the reverse copy operation? is that working as expected?
Copy the pdf File from the Client to NetApp will done in the expected Transmition Time (4 sec)
The problem only occurs duringe the first transfer of a  file from the NetApp Side to client Side.
If this file is transferred back from the client Side to the NetApp Side the transmission time is as expected.
The problem does not occur if a file is first transmitted from the client Side to the NetApp Side.
Here is the transmission time from the beginning well as expected.
The WAE are in Inline Mode
No disk issues
This Problem occurs on a second Client Site too, when they do a upload to the NetApp Side
This Problem occurs on a second Site too, when they do a upload to the NetApp
Again, the same appearance as described in paragraph 4.
For transfers from client to client Side Side is the transmission time, as expected, well
No alarms on both WAE`s
WAAS Client Side:
2010 Sep  6 13:17:21 WAAS-03 Nodemgr: %WAAS-NODEMGR-5-330032: Stopping service: 'actastor_watchdog'.
2010 Sep  6 13:17:21 -WAAS-03 Nodemgr: %WAAS-NODEMGR-5-330036: Stop service 'actastor_watchdog' using: '/sw/acto
na/bin/cifs_stop_process.sh /var/run/actastor.pid Watchdog /local/local1/errorlog/actona/Watchdog.stdout' with pid: 1923
2010 Sep  6 13:17:23 WAAS-03 Nodemgr: %WAAS-NODEMGR-5-330027: Process with pid 5044 exits
2010 Sep  6 13:17:23 WAAS-03 Nodemgr: %WAAS-NODEMGR-5-330048: DEBUG: respawn_count = 1, period: 1678.130000
2010 Sep  6 13:17:23 WAAS-03 Nodemgr: %WAAS-NODEMGR-5-330040: Start service 'actastor_watchdog' using: '/sw/act
ona/bin/actastor_wrapper.sh start' with pid: 19283
2010 Sep  6 13:18:18 WAAS-03 exec_license: %WAAS-CLI-5-170098: The License Transport has not been purchased.
2010 Sep  6 13:21:24 WAAS-03 exec_license: %WAAS-CLI-5-170098: The License Transport has not been purchased.
2010 Sep  6 13:22:52 -WAAS-03 java: %WAAS-CIFSAO-3-131229: (855273) Error getting the security descriptor of 172.16.189.16\Folder\Dokument.pdf, client 10.2.18.205.
2010 Sep  6 13:24:24 -WAAS-03 exec_license: %WAAS-CLI-5-170098: The License Transport has not been purchased.
WAAS NetApp Side:
2010 Sep  6 13:17:21 XxxWAAS01-ACC -admin-shell: %WAAS-UNKNOWN-3-899999: SendReport: PAM session problem
2010 Sep  6 13:17:53 XxxWAAS01-ACC last message repeated 2 times
2010 Sep  6 13:18:12 XxxWAAS01-ACC exec_license: %WAAS-CLI-5-170098: The License Transport has not been purchased.
2010 Sep  6 13:18:31 XxxWAAS01-ACC -admin-shell: %WAAS-UNKNOWN-3-899999: SendReport: PAM session problem
2010 Sep  6 13:18:35 XxxWAAS01-ACC last message repeated 2 times
2010 Sep  6 13:19:33 XxxWAAS01-ACC last message repeated 2 times
2010 Sep  6 13:21:16 XxxWAAS01-ACC -admin-shell: %WAAS-UNKNOWN-3-899999: SendReport: PAM session problem
2010 Sep  6 13:21:18 XxxWAAS01-ACC exec_license: %WAAS-CLI-5-170098: The License Transport has not been purchased.
2010 Sep  6 13:21:19 XxxWAAS01-ACC -admin-shell: %WAAS-UNKNOWN-3-899999: SendReport: PAM session problem
2010 Sep  6 13:22:19 XxxWAAS01-ACC -admin-shell: %WAAS-UNKNOWN-3-899999: SendReport: PAM session problem
2010 Sep  6 13:22:32 XxxWAAS01-ACC -admin-shell: %WAAS-UNKNOWN-3-899999: SendReport: PAM session problem
2010 Sep  6 13:22:47 XxxWAAS01-ACC ntpd[4822]: %WAAS-UNKNOWN-5-899999: time reset +0.186039 s
WAAS NetAppSite:
XxxWAAS01-ACC#sh statistics connection opt cif det
Connection Id:            78
    Peer Id:                  00:21:5e:75:cb:f0
    Connection Type:          EXTERNAL SERVER
    Start Time:               Mon Sep  6 13:50:21 2010
    Source IP Address:        10.2.18.205
    Source Port Number:       63289
    Destination IP Address:   172.16.189.16
    Destination Port Number:  445
    Application Name:         WAFS
    Classifier Name:          CIFS
    Map Name:                 basic
    Directed Mode:            FALSE
    Preposition Flow:         FALSE
    Policy Details:
           Configured:        TCP_OPTIMIZE + DRE + LZ
              Derived:        TCP_OPTIMIZE + DRE + LZ
                 Peer:        TCP_OPTIMIZE + DRE + LZ
           Negotiated:        TCP_OPTIMIZE + DRE + LZ
              Applied:        TCP_OPTIMIZE + DRE + LZ
    Accelerator Details:
                Configured:   CIFS
                   Derived:   CIFS
                   Applied:   CIFS
                      Hist:   None
                                    Original            Optimized
    Bytes Read:                      8685501                14835
    Bytes Written:                     31986              3999130
    Total Reduction Ratio: 53.955%
CIFS : 78
   Time Statistics were Last Reset/Cleared:                           Mon Sep  6 13:50:21 2010
   Total Bytes Read:                                                  41227     8685501
   Total Bytes Written:                                               8700154   31986
   Number of local reply generating requests:                         0
   Number of remote reply generating requests:                        0
   The Average time to generate a local reply (msec):                 0
   Average time to receive remote reply (ms):                         0
DRE : 78
Conn-ID: 78 10.2.18.205:63289 -- 172.16.189.16:445  Peer No:  2 Status: Active
Open at 09/06/2010 13:50:21, Still active
Encode:
   Overall: msg:        462, in:   8496 KB, out:   3900 KB, ratio:  54.09%
       DRE: msg:        349, in:   8453 KB, out:   6505 KB, ratio:  23.04%
DRE Bypass: msg:        493, in:  43584 B
        LZ: msg:        427, in:   6157 KB, out:   3507 KB, ratio:  43.04%
LZ Bypass: msg:         35, in:    390 KB
    Avg latency:      1.464 ms     Delayed msg:        190
  Encode th-put:  12564 KB/s
  Message size distribution:
    0-1K=5%  1K-5K=12%  5K-15K=22%  15K-25K=17%  25K-40K=17%  >40K=24%
Decode:
   Overall: msg:        207, in:   7664 B, out:  41227 B, ratio:  81.41%
       DRE: msg:          6, in:   2453 B, out:   2358 B, ratio:   0.00%
DRE Bypass: msg:        412, in:  38869 B
        LZ: msg:        207, in:   7664 B, out:  42873 B, ratio:  82.12%
LZ Bypass: msg:          0, in:      0 B
    Avg latency:      0.042 ms
  Decode th-put:   4616 KB/s
    0-1K=0%  1K-5K=0%  5K-15K=0%  15K-25K=0%  25K-40K=0%  >40K=0%
Connection details:
  Chunks: encoded 30240,  decoded 20,  anchor(forced) 3251(633)
  Total number of processed messges: 669
   num_used_block per msg: 0.044843
  Ack: msg 6,  size     41 B
  Encode bypass due to:
      last partial chunk: chunks: 208,  size:  43252 B
      skipped frame header: messages: 493,  size:  43584 B
  Nacks: total 0
  R-tx: total 0
  Encode LZ latency:      0.982 ms per msg
  Decode LZ latency:      0.020 ms per msg
  Aggregation encode:  Retransmissions: 0
      level 0: chunks:    30050  hits:     7567 miss:    22483
      level 1: chunks:        0  hits:        0 miss:        0
      level 2: chunks:        0  hits:        0 miss:        0
      level 3: chunks:        0  hits:        0 miss:        0
  Aggregation decode: Collisions: 0
      level 0: chunks:        0  hits:        0 miss:        0
  Aggregation stack memory usage: Sender:  21647 B  Receiver:   3126 B
  Noise filter: Chunks: 285, Bytes:  69991 B
TFO : 78
  Conn-Type:    EXTSERVER             Policy: DRE+LZ
  EOT state:
     Write: req: N, ack: N,  Read: req: N, ack: N
  Socket states
     AO : read-shut: N,  write-shut: N,  close: N, fd: 71
          read-inKQ: Y,  write-inKQ: N,  choke: N, envoy: Y
     WAN: read-shut: N,  write-shut: N,  close: N, fd: 70
          read-inKQ: Y,  write-inKQ: N,  choke: N, envoy: N
  DRE hints:
     local   : latency: 1 plz-off: 0, lz-off: 0, dre-off: 0
     remote  : latency: 1 plz-off: 0, lz-off: 0, dre-off: 0
     active  : latency: 1 plz-off: 0, lz-off: 0, dre-off: 0
  Scheduler:    class_id: 0   dscp: 0
                             Encode-Flow             Decode-Flow
  Read
     Total bytes:              8700154                     14835
     Total number:                 384                       469
     Average size:               22656                        31
     Schd latency(ms):            0.02                      0.03
     Stop latency(ms):            0.00                      0.00
     Read latency(ms):            0.02                      0.01
     Flow-ctrl stop:                 1                         0
     Peer-choke:                     0                         0
     Processed ack frames:                                   337
  Decoder pending queue:
     Maximum size:                                             0
     Current size:                                             0
     Average size:                                             0
     Flow-ctrl stop:                                           0
  Encode/Decode:
     Number of calls:              493                       207
     Latency(ms):                 1.37                      0.04
     Send data/ack frames:         462                         1
  Writer pending queue
     Maximum size:               19418                         0
     Current size:                   0                         0
     Average size:                  88                         0
     Flow-ctrl stop:                 3                         0
  Write
     Total bytes:              3999130                     41227
     Total number:                 465                       207
     Avergage size:               8600                       199
     Latency(ms):                 0.04                      0.01
WAAS Client Site:
WAAS-03#sh statistics connection opt cif det
Connection Id:            546
    Peer Id:                  00:1a:64:f2:49:49
    Start Time:               Mon Sep  6 13:27:35 2010
    Source IP Address:        172.28.7.30
    Source Port Number:       2224
    Destination IP Address:   10.1.0.89
    Destination Port Number:  139
    Map Name:                 basic
    Policy Details:
                Configured:   CIFS
                   Derived:   CIFS
                   Applied:   CIFS
                      Hist:   None
                                    Original            Optimized
    Bytes Read:                          523                  875
    Bytes Written:                      1804                  507
    Total Reduction Ratio: 40.610%
CIFS : 546
   Time Statistics were Last Reset/Cleared:                           Mon Sep  6 13:27:35 2010
   Total Bytes Read:                                                  1251      523
   Total Bytes Written:                                               708       1804
DRE : 546
Conn-ID: 546 172.28.7.30:2224 -- 10.1.0.89:139  Peer No:  0 Status: Active
Open at 09/06/2010 13:27:35, Still active
Encode:
   Overall: msg:          5, in:    708 B, out:    396 B, ratio:  44.07%
       DRE: msg:          0, in:      0 B, out:      0 B, ratio:   0.00%
DRE Bypass: msg:          5, in:    708 B
        LZ: msg:          5, in:    783 B, out:    396 B, ratio:  49.43%
    Avg latency:      0.085 ms     Delayed msg:          0
  Encode th-put:   1634 KB/s
Decode:
   Overall: msg:          7, in:    744 B, out:   1251 B, ratio:  40.53%
       DRE: msg:          1, in:    333 B, out:    308 B, ratio:   0.00%
DRE Bypass: msg:         13, in:    943 B
        LZ: msg:          7, in:    744 B, out:   1365 B, ratio:  45.49%
    Avg latency:      0.038 ms
  Decode th-put:   4592 KB/s
Connection details:
  Chunks: encoded 0,  decoded 1,  anchor(forced) 0(0)
  Total number of processed messges: 12
   num_used_block per msg: 0.000000
  Ack: msg 1,  size     41 B
      skipped frame header: messages: 5,  size:    708 B
  Nacks: total 0
  R-tx: total 0
  Encode LZ latency:      0.052 ms per msg
  Decode LZ latency:      0.015 ms per msg
  Aggregation stack memory usage: Sender:      0 B  Receiver:    332 B
  Noise filter: Chunks: 0, Bytes:      0 B
TFO : 546
  EOT state:
  Socket states
     AO : read-shut: N,  write-shut: N,  close: N, fd: 118
     WAN: read-shut: N,  write-shut: N,  close: N, fd: 117
  DRE hints:
  Read
     Total bytes:                  708                       875
     Total number:                   5                         9
     Average size:                 141                        97
     Schd latency(ms):            0.02                      0.02
     Read latency(ms):            0.01                      0.01
     Flow-ctrl stop:                 0                         0
     Peer-choke:                     0                         0
     Processed ack frames:                                     1
     Maximum size:                                             0
     Current size:                                             0
     Average size:                                             0
     Flow-ctrl stop:                                           0
  Encode/Decode:
     Number of calls:                5                         7
     Latency(ms):                 0.09                      0.04
     Send data/ack frames:           5                         1
    Maximum size:                   0                         0
     Current size:                   0                         0
     Average size:                   0                         0
     Flow-ctrl stop:                 0                         0
  Write
     Total bytes:                  507                      1251
     Total number:                   7                         7
     Avergage size:                 72                       178
     Latency(ms):                 0.02                      0.01
Connection Id:            869
    Peer Id:                  00:21:5e:75:91:d4
    Connection Type:          EXTERNAL CLIENT
    Map Name:                 basic
    Policy Details:
                Configured:   CIFS
                   Derived:   CIFS
                   Applied:   CIFS
                      Hist:   None
                                    Original            Optimized
    Bytes Read:                        56281              3999130
    Bytes Written:                   6342242                14835
    Total Reduction Ratio: 37.267%
CIFS : 869
   Total Bytes Read:                                                  56281     8700154
   Total Bytes Written:                                               6342242   41227
   Number of local reply generating requests:                         381
   Number of remote reply generating requests:                        196
   The Average time to generate a local reply (msec):                 16423
   Average time to receive remote reply (ms):                         1229322
DRE : 869
Conn-ID: 869 10.2.18.205:63289 -- 172.16.189.16:445  Peer No:  1 Status: Active
Encode:
   Overall: msg:        207, in:  41227 B, out:   7664 B, ratio:  81.41%
       DRE: msg:          6, in:   2358 B, out:   2453 B, ratio:   0.00%
DRE Bypass: msg:        211, in:  38869 B
        LZ: msg:        207, in:  42873 B, out:   7664 B, ratio:  82.12%
    Avg latency:      0.097 ms     Delayed msg:          4
  Encode th-put:   2006 KB/s
Decode:
   Overall: msg:        462, in:   3900 KB, out:   8496 KB, ratio:  54.09%
       DRE: msg:        349, in:   6505 KB, out:   8453 KB, ratio:  23.04%
DRE Bypass: msg:        606, in:  43584 B
        LZ: msg:        427, in:   3507 KB, out:   6157 KB, ratio:  43.04%
LZ Bypass: msg:         35, in:    393 KB
    Avg latency:      0.473 ms
  Decode th-put:  38850 KB/s
Connection details:
  Chunks: encoded 24,  decoded 23061,  anchor(forced) 8(0)
   num_used_block per msg: 0.031390
  Ack: msg 349,  size   1721 B
      last partial chunk: chunks: 10,  size:    257 B
      skipped frame header: messages: 211,  size:  38869 B
  Nacks: total 0
  R-tx: total 0
  Encode LZ latency:      0.062 ms per msg
  Decode LZ latency:      0.122 ms per msg
      level 0: chunks:       20  hits:        0 miss:       20
      level 0: chunks:        0  hits:     7282 miss:        0
  Aggregation stack memory usage: Sender:   2758 B  Receiver:  21645 B
10.  Asymmetric routing
There is no asymetric Routing
I hope the information is detailed enough.
Regards Andreas
Hi Andreas,
Looks like this is a CIFS related issue. We will need to look at sysreport from client and server side waas. is it possible for you to upload sysreport from the  server side and client side waes. If possible, please also work with TAC to get this analyzed throughly for CIFS issue.
Looks like CIFS AO is restarting frequently.
We may have to do packet capture on server and client side WAEs and look at the transfer session.
Regards.
Bhavin Yadav
And one more thing and a very important point: Asymmetric routing. With asymmetric routing, transmit and receive packets follow different       paths between a host and the peer with which it communicates.
More  details about Asymmetric routing in general is here:  http://www.cisco.com/web/services/news/ts_newsletter/tech/chalktalk/archives/200903.html
To find out if WAE is having any connections in Asymmetric table is to use the command:
show stat conn pass | in Asymmetric
And  watch for any connection with PT Asymmetric. The connection will remain  in PT Asymmetric state for very little time before it goes to PT Pass  through.
Another CLI command is to check history of PT Asymmetric. Cli command: show stat pass | in Asymmetric.
If  you see any of the two counters increasing, then possibly Asymmetric  routing is the issue. Then we have to find out if our conenction to  NetApp is also having Asymmetric issue.
