ACS 5.1 and Multiple AD Domains
Answered Question
Sep 2nd, 2010
Guys I have ACS 5.1 running on a VM Instance.  I was able to add the ACS server to my AD domain and it is working correctly.  However I have other users in a different domain that I would like to use this ACS server to login to devices.  Is there way to connect to two different AD domains from this server.
Thanks in advance,
MikeP
Correct Answer by Waris Hussain about 6 years 5 months ago
Hi ,
In ACS5.1  you can join only one domain to which ACS will join.
Waris Hussain.
Overall Rating: 5 (1 ratings)
Correct Answer
Waris Hussain Thu, 09/02/2010 - 09:57
Hi ,
Waris Hussain.
mapones Thu, 09/02/2010 - 10:59
Thanks for the quick reply.  I thought that was the case, I just did some checking with my AD guys and it looks like since there is a "Trust" between our domains we can specify the domain_name\userid and it works.  That will be my workaround until we migrate everyone to the new domain.
Thanks again!!!
MikeP
Mikayil Qasimov Mon, 07/15/2013 - 05:57
Hi Mapones,
This topic too old, But I wanna to configure like this option with multiple AD. But it's not working. PLease give some suggestions.
mapones Mon, 07/15/2013 - 09:15
When I originally installed this you could only connect to one domain.  It looks like in 5.4 it looks like you might be able to connet to more then one, but I have not tested it.
Good luck
Mike
Related Content
