Multicontext Login
Sep 2nd, 2010
We are deploying a pair of 5580's in multi-context.  Each context will have a separate group doing the administrator.  I know that you can configure management to each context via an interface in the context.  What I would like to know if there a way using RADIUS or TACACS, can you control management via an Attribute, for example the OU attribute, in the same way you can use the OU to assign a Group Policy when using VPN features.
Kureli Sankar Thu, 09/02/2010 - 19:05
  • Cisco Employee,
I believe this is possible. But, the best area to move this thread would be to the AAA section under Security.
-KS
