Mobile Agent 7.5 Invalid Instrument
Sep 2nd, 2010
Can anybody help me diagnose my config issue for IPCC Error [12005} Login could not be performed - Possible casuses are Invalid Instrument ?
This is my attempt to configure my first mobile agent using the following config:
Sprawler 7.5
Device target
Global Address: LCP5000F0000
Configuration parameters: /devtype ciscophone /dn 4002151
CUCM 7.1
CTI port: LCP5000F0000
Line: 4002151
CTI port: RCP5000F0000
Line: 4002150
Agent Login
Agent ID: 8315
Instrument: 4002151
Phone Number: 4009999
Call Mode: Nailed connection
PGUser is is my PG configured application user and is associated with the two devices, te association seems to be working as the CTI ports go registered.
However, when I try to login in my agent I get the login issue. I've tried adding an /ext 4002151 and /ext 5000F000 but neither attempt helped.
I've looked at the JTAPI logs and I see an attempt to make the outbound call to 4009999 but the CUCM response is state=DISCONNECTED cause=UNALLOCATEDNUMBER.
Any ideas?
jedellerby Fri, 09/03/2010 - 10:11
I missed the label info off my above description:
Device Label
Routing Client: WHP_CCM.RX
Label: 4002151
Label Type: Normal
Customer: WHP
I've now made progress and found out the CSS on the CUCM for the CTI ports was incorrect and couldn't make outbound calls to the phone number I was testing against ... so now I can log in.
Unfortunatly I now find that MA works if I am in a ready state, but if the calls gets queued via the IPIVR 7.0 server then the call gets dropped when the agent goes ready and a transfer is initiated to the agent. The IVR CTI ports seems to have the correct CSS so I'm a bit confused about this one, more debugging required.
