%ASA-5-305013: Asymmetric NAT rules matched for forward and reverse flows; Connection denied due to NAT reverse path failure. VPN client issues after 8.3 upgrade.
Answered Question
Sep 2nd, 2010
We have ASA 5510 & upgraded to 8.3 recently. Now we are having
some issues accessing to our network. I have already read
https://supportforums.cisco.com/docs/DOC-12569 and
https://supportforums.cisco.com/message/3168125#3168125
but didn't help.
Our networks are
Trust (Inside): 172.28.10.0/24
DMZ: 172.28.5.0/24
VPN Pool: 172.28.8.0/24
From remote client, we can access to any hosts in inside segment,
however we cannot access any hosts in DMZ segment. when I ping
to a host in DMZ segment, I get following log.
Asymmetric NAT rules matched for forward and reverse flows; Connection for icmp
src Untrust:172.28.8.109 dst DMZ:172.28.5.10 (type 8, code 0) denied due to
here is the log of sh nat
#sh nat
Manual NAT Policies (Section 1)
1 (Trust) to (any) source static DCT DCT destination static DLST DLST
     translate_hits = 360138, untranslate_hits = 78801
2 (Trust) to (any) source static DCT DCT destination static DLSV DLSV
     translate_hits = 116, untranslate_hits = 8992
3 (Trust) to (any) source static DCT DCT destination static DLSD DLSD
     translate_hits = 8, untranslate_hits = 0
4 (Trust) to (any) source static DDCT DCT destination static DETT DETT
     translate_hits = 1309, untranslate_hits = 52569
5 (Trust) to (any) source static DCT DCT destination static DETD DETD
     translate_hits = 35, untranslate_hits = 0
6 (Trust) to (any) source static DCT DCT destination static CPNT CPNT
     translate_hits = 118052, untranslate_hits = 44007
7 (DMZ) to (Untrust) source static DCD DCD destination static DLST DLST
     translate_hits = 9, untranslate_hits = 24
8 (DMZ) to (Untrust) source static DCD DCD destination static DLSV DLSV
     translate_hits = 0, untranslate_hits = 4
9 (DMZ) to (Untrust) source static DCD DCD destination static DLSD DLSD
     translate_hits = 17, untranslate_hits = 3
10 (DMZ) to (Untrust) source static DCD DCD destination static DETT DETT
     translate_hits = 2, untranslate_hits = 20
11 (DMZ) to (Untrust) source static DCD DCD destination static DETD DETD
     translate_hits = 2, untranslate_hits = 0
12 (DMZ) to (Untrust) source static DCD DCD destination static CPNT CPNT
     translate_hits = 22, untranslate_hits = 85
13 (Trust) to (Untrust) source static DCT DCT destination static our_company our_company
     translate_hits = 13, untranslate_hits = 2636
14 (Trust) to (Untrust) source static any any destination static DCV DCV
     translate_hits = 650, untranslate_hits = 11466
15 (DMZ) to (Untrust) source static any any destination static DCV DCV
     translate_hits = 0, untranslate_hits = 0
Auto NAT Policies (Section 2)
1 (DMZ) to (Untrust) source static FT01 "external IP 3" service tcp ftp ftp
2 (DMZ) to (Untrust) source static Barracuda "external IP 2"
     translate_hits = 0, untranslate_hits = 31884
3 (Trust) to (Untrust) source static EX01 "external IP 1"
     translate_hits = 1245, untranslate_hits = 95428
4 (Trust) to (Untrust) source static MT01 "external IP 3" service tcp www www
     translate_hits = 0, untranslate_hits = 200
5 (Trust) to (Untrust) source dynamic obj_any interface
     translate_hits = 27787, untranslate_hits = 1325
6 (DMZ) to (Untrust) source dynamic obj_any-01 interface
     translate_hits = 719, untranslate_hits = 20
Object:
DCT: 172.28.10.0/24
DCD: 172.28.5.0/24
DCV: 172.28.8.0/24
DLST: 172.28.40.0/24
DLSD: 172.28.63.0/24
DLSV: 172.28.62.0/24
DETT: 172.28.52.0/24
DETD: 172.28.64.0/24
CPNT: 172.28.30.0/24
FT01: 172.28.5.10
Barracuda: 172.28.5.250
EX01: 172.28.10.12
MT01: 172.28.10.14
Correct Answer by Kureli Sankar about 6 years 7 months ago
This case is now resolved.
Due to this defect http://tools.cisco.com/Support/BugToolKit/search/getBugDetails.do?method=fetchBugDetails&bugId=CSCth24401
we could not find which nat rule was overlapping up above.
Symptom:
Packet tracer doesn't indicate all the overlapping NAT configurations when there is an rpf-check failure.
Conditions:
This is a basic functionality of packet tracers.
Workaround:
There is no known workaround.
We removed this line
nat (DMZ,Untrust) source static DC_DMZ DC_DMZ destination static DC_VPN DC_VPN
and added it as line 1
nat (DMZ,Untrust) 1 source static DC_DMZ DC_DMZ destination static DC_VPN DC_VPN
-KS
Overall Rating: 5 (1 ratings)
praprama Thu, 09/02/2010 - 18:39
  • Cisco Employee,
Can you attach the output of "show run nat". I am not sure why it's not working as the below rule should be taking effect:
Prapanch
Kureli Sankar Thu, 09/02/2010 - 18:48
  • Cisco Employee,
Could you pls. collect the output of the below command
  packet-tracer DMZ inside icmp 172.28.5.10 0 4 172.28.8.109 det
-KS
ny_takeshi Fri, 09/03/2010 - 15:43
Hello kusankar,
Thank you very much for your kind reply.
Unfortunately the command didn't run.
I replaced IP, interface to
packet-tracer DMZ Trust icmp 172.28.5.10 0 4 172.28.8.113 det
but got error on DMZ, for some reason...
Thank you very much.
Kureli Sankar Fri, 09/03/2010 - 15:48
  • Cisco Employee,
Sorry  I meant to say
packet-tracer DMZ icmp 172.28.5.10 0 4 172.28.8.113 det
-KS
Nagaraja Thanthry Fri, 09/03/2010 - 16:02
  • Cisco Employee,
A keyword "input" is missing:
packet-tracer input Trust icmp 172.28.5.10 0 4 172.28.8.113 det
NT
ny_takeshi Fri, 09/03/2010 - 15:39
Here is the result of "sh run nat"
# sh run nat
nat (Trust,any) source static DCT DCT destination static DLST DLST
nat (Trust,any) source static DCT DCT destination static DLSV DLSV
nat (Trust,any) source static DCT DCT destination static DLSD DLSD
nat (Trust,any) source static DCT DCT destination static DETT DETT
nat (Trust,any) source static DCT DCT destination static DETD DETD
nat (Trust,any) source static DCT DCT destination static CPNT CPNT
nat (DMZ,Untrust) source static DCD DCD destination static DLST DLST
nat (DMZ,Untrust) source static DCD DCD destination static DLSV DLSV
nat (DMZ,Untrust) source static DCD DCD destination static DLSD DLSD
nat (DMZ,Untrust) source static DCD DCD destination static DETT DETT
nat (DMZ,Untrust) source static DCD DCD destination static DETD DETD
nat (DMZ,Untrust) source static DCD DCD destination static CPNT CPNT
nat (Trust,Untrust) source static DCT DCT destination static "our_company" "our_company"
nat (Trust,Untrust) source static any any destination static DCV DCV
nat (DMZ,Untrust) source static any any destination static DCV DCV
object network MT01
nat (Trust,Untrust) static public IP 3 service tcp www www
object network EX01
nat (Trust,Untrust) static public IP 1
object network obj_any
nat (Trust,Untrust) dynamic interface
object network obj_any-01
nat (DMZ,Untrust) dynamic interface
object network FT01
nat (DMZ,Untrust) static public IP 3 service tcp ftp ftp
object network Barracuda
nat (DMZ,Untrust) static Public IP 2
Thank you very much
ny_takeshi Fri, 09/03/2010 - 16:04
Hello kusankar
it didn't work, but i worked it out.
here is the result.
# packet-tracer input Trust icmp 172.28.5.10 0 4 172.28.8.113 det
Phase: 1
Type: ROUTE-LOOKUP
Subtype: input
Result: ALLOW
Config:
Additional Information:
in   172.28.8.113    255.255.255.255 Untrust
Phase: 2
Type: IP-OPTIONS
Subtype:
Result: ALLOW
Config:
Forward Flow based lookup yields rule:
in  id=0xacba90f0, priority=0, domain=inspect-ip-options, deny=true
        hits=902666, user_data=0x0, cs_id=0x0, reverse, flags=0x0, protocol=0
        src ip/id=0.0.0.0, mask=0.0.0.0, port=0
        dst ip/id=0.0.0.0, mask=0.0.0.0, port=0, dscp=0x0
        input_ifc=Trust, output_ifc=any
Phase: 3
Type: INSPECT
Subtype: np-inspect
Result: ALLOW
Config:
class-map inspection_default
match default-inspection-traffic
policy-map global_policy
class inspection_default
  inspect icmp
service-policy global_policy global
in  id=0xad4044c0, priority=70, domain=inspect-icmp, deny=false
        hits=356641, user_data=0xad404818, cs_id=0x0, use_real_addr, flags=0x0, protocol=1
Phase: 4
Type: INSPECT
Subtype: np-inspect
Result: ALLOW
Config:
in  id=0xacba8d58, priority=66, domain=inspect-icmp-error, deny=false
        hits=384117, user_data=0xacba8c40, cs_id=0x0, use_real_addr, flags=0x0, protocol=1
Phase: 5
Type: NAT
Subtype:
Result: ALLOW
Config:
nat (Trust,Untrust) source static any any destination static DC_VPN DC_VPN
Static translate MEC-FT01/0 to MEC-FT01/0
in  id=0xad6470f0, priority=6, domain=nat, deny=false
        hits=2255, user_data=0xad646a80, cs_id=0x0, use_real_addr, flags=0x0, protocol=0
        dst ip/id=172.28.8.0, mask=255.255.255.0, port=0, dscp=0x0
        input_ifc=Trust, output_ifc=Untrust
Phase: 6
Type: VPN
Subtype: encrypt
Result: ALLOW
Config:
out id=0xad593b50, priority=70, domain=encrypt, deny=false
        hits=1, user_data=0x855e454, cs_id=0x0, reverse, flags=0x0, protocol=0
        dst ip/id=172.28.8.113, mask=255.255.255.255, port=0, dscp=0x0
        input_ifc=any, output_ifc=Untrust
Phase: 7
Type: FLOW-CREATION
Subtype:
Result: ALLOW
Config:
New flow created with id 1006626, packet dispatched to next module
Module information for forward flow ...
snp_fp_tracer_drop
snp_fp_inspect_ip_options
snp_fp_inspect_icmp
snp_fp_translate
snp_fp_adjacency
snp_fp_encrypt
snp_fp_fragment
snp_ifc_stat
Module information for reverse flow ...
Result:
input-interface: Trust
input-status: up
input-line-status: up
output-interface: Untrust
output-status: up
output-line-status: up
Action: allow
Kureli Sankar Fri, 09/03/2010 - 16:40
  • Cisco Employee,
Trust : 172.28.10.0/24
DMZ: 172.28.5.0/24
Asymmetric NAT rules matched for forward and reverse flows; Connection for icmp src Untrust:172.28.8.109 dst DMZ:172.28.5.10 (type 8, code 0) denied due to NAT reverse path failure
packet-tracer input DMZ icmp 172.28.5.10 0 4 172.28.8.113 det
packet-tracer input Untrust icmp 172.28.8.113 0 8  172.28.5.10 det
One more time. The above two outputs pls. Just "?" mark your way if the commands don't take as we type it on the fly and I apologize for missing the "input" keyword that NT caught very quickly.
BTW,
I don't see this line nat (Trust,Untrust) source static any any destination static DC_VPN DC_VPN
in the sh run nat output how come?
-KS
ny_takeshi Tue, 09/07/2010 - 08:49
Hello Kusankar,
here are the log for the commands.
# packet-tracer input DMZ icmp 172.28.5.10 0 4 172.28.8.113 det
Phase: 1
Type: ROUTE-LOOKUP
Subtype: input
Result: ALLOW
Config:
Phase: 2
Type: IP-OPTIONS
Subtype:
Result: ALLOW
Config:
in  id=0xacbcf428, priority=0, domain=inspect-ip-options, deny=true
        hits=64585, user_data=0x0, cs_id=0x0, reverse, flags=0x0, protocol=0
        input_ifc=DMZ, output_ifc=any
Phase: 3
Type: INSPECT
Subtype: np-inspect
Result: ALLOW
Config:
  inspect icmp
in  id=0xad405e58, priority=70, domain=inspect-icmp, deny=false
        hits=134, user_data=0xad404818, cs_id=0x0, use_real_addr, flags=0x0, pro
tocol=1
Phase: 4
Type: INSPECT
Subtype: np-inspect
Result: ALLOW
Config:
in  id=0xacbcf090, priority=66, domain=inspect-icmp-error, deny=false
        hits=134, user_data=0xacbcef78, cs_id=0x0, use_real_addr, flags=0x0, pro
tocol=1
Phase: 5
Type: VPN
Subtype: ipsec-tunnel-flow
Result: ALLOW
Config:
in  id=0xad631098, priority=13, domain=ipsec-tunnel-flow, deny=true
        hits=83, user_data=0x0, cs_id=0x0, flags=0x0, protocol=0
Phase: 6
Type: NAT
Subtype:
Result: ALLOW
Config:
in  id=0xad499c20, priority=6, domain=nat, deny=false
        hits=1, user_data=0xad582f20, cs_id=0x0, use_real_addr, flags=0x0, protocol=0
        input_ifc=DMZ, output_ifc=Untrust
Phase: 7
Type: VPN
Subtype: encrypt
Result: ALLOW
Config:
out id=0xac87ded0, priority=70, domain=encrypt, deny=false
        hits=1, user_data=0x99127ec, cs_id=0x0, reverse, flags=0x0, protocol=0
Phase: 8
Type: FLOW-CREATION
Subtype:
Result: ALLOW
Config:
New flow created with id 1150310, packet dispatched to next module
snp_fp_tracer_drop
snp_fp_inspect_icmp
snp_fp_translate
snp_fp_adjacency
snp_fp_encrypt
snp_fp_fragment
snp_ifc_stat
Result:
input-interface: DMZ
input-status: up
output-status: up
Action: allow
# packet-tracer input Untrust icmp 172.28.8.113 0 8  172.28.5.10 det
Phase: 1
Type: ACCESS-LIST
Subtype:
Result: ALLOW
Config:
Implicit Rule
in  id=0xacad83e0, priority=1, domain=permit, deny=false
        hits=34963188, user_data=0x0, cs_id=0x0, l3_type=0x8
        src mac=0000.0000.0000, mask=0000.0000.0000
        dst mac=0000.0000.0000, mask=0100.0000.0000
        input_ifc=Untrust, output_ifc=any
Phase: 2
Type: ROUTE-LOOKUP
Subtype: input
Result: ALLOW
Config:
Phase: 3
Type: ACCESS-LIST
Subtype:
Result: DROP
Config:
Implicit Rule
in  id=0xa7f80050, priority=11, domain=permit, deny=true
        hits=182336, user_data=0x5, cs_id=0x0, flags=0x0, protocol=0
Result:
input-interface: Untrust
input-status: up
output-status: up
Action: drop
Drop-reason: (acl-drop) Flow is denied by configured rule
Thank you very much!
Tak
ny_takeshi Wed, 09/08/2010 - 12:46
Hello Kusankar,
I forgot to reply to your question.
I modified the original config a bit. just object names. DC_VPN = DCV
Takeshi
Kureli Sankar Sat, 09/11/2010 - 18:10
  • Cisco Employee,
Takeshi,
Sorry for the delay.
Result:
Action: allow
The above output looks ok.
Result:
Action: drop
The above output says the source and the destination are out the Untrust interface.
Pls. check the route. What do your "sh route | i 172.28.5.0" and "sh route | i 172.28.8.0" say? Do they show the correct interface?
-KS
ny_takeshi Tue, 09/14/2010 - 16:19
Hello Kusankar,
Thank you very much for your kind attention & comments.
I ran the command you specified below, but didn't return anything.
just in case, I just ran "sh route" without output modifier.
# sh route
Codes: C - connected, S - static, I - IGRP, R - RIP, M - mobile, B - BGP
       D - EIGRP, EX - EIGRP external, O - OSPF, IA - OSPF inter area
       N1 - OSPF NSSA external type 1, N2 - OSPF NSSA external type 2
       E1 - OSPF external type 1, E2 - OSPF external type 2, E - EGP
       i - IS-IS, L1 - IS-IS level-1, L2 - IS-IS level-2, ia - IS-IS inter area
       * - candidate default, U - per-user static route, o - ODR
       P - periodic downloaded static route
Gateway of last resort is "GW IP" to network 0.0.0.0
S    172.17.0.0 255.255.0.0 [1/0] via 172.28.10.1, Trust
S    172.16.0.0 255.255.0.0 [1/0] via 172.28.10.1, Trust
S    172.19.0.0 255.255.0.0 [1/0] via 172.28.10.1, Trust
S    172.18.0.0 255.255.0.0 [1/0] via 172.28.10.1, Trust
S    172.21.0.0 255.255.0.0 [1/0] via 172.28.10.1, Trust
S    172.20.0.0 255.255.0.0 [1/0] via 172.28.10.1, Trust
S    172.24.0.0 255.255.0.0 [1/0] via 172.28.10.1, Trust
S    172.27.0.0 255.255.0.0 [1/0] via 172.28.10.1, Trust
C    DCD 255.255.255.0 is directly connected, DMZ
C    DCT 255.255.255.0 is directly connected, Trust
S    172.28.8.116 255.255.255.255 [1/0] via "GW IP", Untrust  --> Currently someone is accessing via VPN
S    172.28.8.118 255.255.255.255 [1/0] via "GW IP", Untrust  --> Currently someone is accessing via VPN
S    172.28.8.108 255.255.255.255 [1/0] via "GW IP", Untrust  --> Currently someone is accessing via VPN
C    "Public Network Address" 255.255.255.248 is directly connected, Untrust
S*   0.0.0.0 0.0.0.0 [1/0] via "GW IP", Untrust
Thank you very much in advance!!
Takeshi
Kureli Sankar Mon, 09/20/2010 - 20:33
  • Cisco Employee,
Takeshi,
I suggest you open a TAC case as we need to collect a bunch of output while ping -t is going on between the two hosts.
The route looks ok but, still the packet tracker output is clearly getting dropped.
-KS
ny_takeshi Tue, 09/21/2010 - 08:59
Hello Kusankar,
Thank you very much for your kind assistance.
I have created a TAC case. Hope they can help me.
Again, Thank you sooo much for your help.
Best Regards,
Takeshi
Correct Answer
Kureli Sankar Tue, 09/21/2010 - 11:53
  • Cisco Employee,
Symptom:
Conditions:
Workaround:
-KS
ny_takeshi Tue, 09/21/2010 - 12:06
Hello Kusankar,
Thank you very much for your great help!
Best Regards,
Takeshi
