TCL Script
Sep 2nd, 2010
Greeting all
Does anyone have a TCL script that will execute a bunch of command , in other word the same as even manager with the event none (i don`t have the license for ip service to have EEM so i`m looking for a script that u can tell him in just one line to execute a bunch of CLI command
thanks
Joe Clarke Thu, 09/02/2010 - 22:37
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
This is very easy to do in tclsh.  Here's an example:
set output [exec "show version"]
append output [exec "show ip int brie"]
append output [exec "show proc cpu"]
puts $output
Seifeddine-Tlili Fri, 09/03/2010 - 05:42
Hi Joseph thanks for your reply i really appeciate it
So basically if i`d like to replace these commands:
event manager applet ShutDown
event none
action 1.0 cli command "en"
action 2.0 cli command "conf t "
action 3.0 cli command "int range fas 1/0/1-12"
action 4.0 cli command "description Event Working"
event manager applet RUN
action 1.0 cli command "EEM"
alias exec EEM event manager run ShutDown
i`ll have to create a scritp with the following lines
First one DESCRIPTION.tcl
set output [exec "en"}
append output [configure "int range fas1/0/1-12"]
append output [interface "description Event Working"]
then using kron i`ll invoque the scrit periodically using the command tclsh DESCITION.tcl
Is that correct ...sorry but i`m really not confortable with scripting
Joe Clarke Fri, 09/03/2010 - 23:49
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
You want:
ios_config "int range fas 1/0/1-12" "description Event Working" "end"
That's all the tclsh script you'd need for your EEM applet.
