Nexus 5K/2K question
Sep 2nd, 2010
HI,
I am trying to simply add a port on the N2148 to a VLAN. Once I added it the interface is still showing inactive.
Is there anything else I need to do?
Randall
Atif Awan Tue, 09/07/2010 - 17:25
  • Cisco Employee,
Have you created the VLAN using the 'vlan X' command? If not then please do this on the 5K and the port should revert to ACTIVE.
Atif
rcrumm_2 Wed, 09/08/2010 - 09:04
It ended up being I needed to connfigure the other 5K FEX port as well and it came active.
RC
Atif Awan Wed, 09/08/2010 - 09:48
  • Cisco Employee,
Your original post did not mention you were running FEX in Active/Active configuration. Anyways, as of now manual configuration synchronization is required between the two N5Ks for FEX in Active/Active.
Atif
