DSP error
Muralidharan.p
Hi All,
we are having 2 analog lines connected to 2 fxo ports. Port 0/1/0(594) and 0/1/1(671). If i try to call the number 594 the call is working fine but if try to call 671 its not working, im able to hear the ringing sound but the call is not established. Im getting the following DSP error in my router and i found that the rotuer is hitting the Bug ID CSCse34097.
mbrd_e1t1_vic_connect: setup failed
flex_dsprm_voice_connect: voice tdm connect failed: voice-port(0/1/1), dsp_channel(/0/0/2).
Look the following output, when i dial the number 671 show voice call summary is showing rining but show voice port summary is still in on hook can any one explain me wat is the issue. And also let me know due to this error the call is not working
sh voice cal su
PORT           CODEC    VAD VTSP STATE            VPM STATE
0/1/0         g729r8    n  S_CONNECT             FXOLS_CONNECT
0/1/1         -         -  -
FXOLS_RINGING
sh voic p s
PORT      CH   SIG-TYPE   ADMIN OPER STATUS   STATUS   EC
0/1/0     --  fxo-ls      up    up   idle     off-hook y
0/1/1     --  fxo-ls      up    up   idle     on-hook  y
11 Replies 11
paolo bevilacqua
Update IOS and try again.
Steven Holl
Yeah that bug was fixed about 4 years ago.  It is a DSP issue, which is going to mess up analog port states, since those are dependent on the DSP.
Are you running really old IOS?  Can you post a 'sh ver?'  If you are running a recent IOS, it may be a recurrence or new iteration of a related issue.
-Steve
Hi , experts:
when i show voice call summany, have the S_SETUP_FAIL in  the output as the below,and i must shut and no shutdown controller t1 then it's work fine ,who can help me to troubleshooting and give me some guidance how to do it
1/0/0:1.10      g711ulaw   n  S_SETUP_FAIL          EM_GUARD_ALL_RLS_REQ
1/0/0:1.11      g729r8     y  S_CONNECT             EM_CONNECT
1/0/0:1.12      g729r8     n  S_CONNECT             EM_CONNECT
1/0/0:1.13      g729r8     n  S_CONNECT             EM_CONNECT
1/0/0:1.14      g729r8     y  S_CONNECT             EM_CONNECT
1/0/0:1.15      g729r8     n  S_CONNECT             EM_CONNECT
1/0/0:1.16      -          -  -                                 EM_ONHOOK
What IOS are you running?
You likely need VPM debug during an issue to identify what's occurring, and if it is a PBX issue or an old/new bug in IOS.
hi, sir :
thanks your reply, my router is cisco 3845 and the ios version is (C3845-IPVOICEK9-M), Version 12.4(24)T
only one or two occur daily and i can't know what time this happened, so it's a little difficulty to debug it.
can you give me some further suggestion to troubleshooting this problem
Hi, Sir :
I have a VWIC-1MFT-T1= voice card and have five PVDM2-12 on the voice card ,but when I show show dsp only 24 channel displayed,
whether are three PVDM-12 not active or others reason?
Wj_F1_1#show inventory | in PVDM
NAME: "PVDMII DSP SIMM with four DSPs on Slot 0 SubSlot 7", DESCR: "PVDMII DSP SIMM with four DSPs"
PID: PVDM2-64          , VID: V01 , SN: FOC10140VVE
NAME: "PVDM 3-C549 Simm on Slot 1 SubSlot 1", DESCR: "PVDM 3-C549 Simm"
PID: PVDM-12=          , VID:    , SN:
NAME: "PVDM 3-C549 Simm on Slot 1 SubSlot 2", DESCR: "PVDM 3-C549 Simm"
NAME: "PVDM 3-C549 Simm on Slot 1 SubSlot 3", DESCR: "PVDM 3-C549 Simm"
NAME: "PVDM 3-C549 Simm on Slot 1 SubSlot 4", DESCR: "PVDM 3-C549 Simm"
NAME: "PVDM 3-C549 Simm on Slot 1 SubSlot 5", DESCR: "PVDM 3-C549 Simm"
Wj_F1_1#show voice dsp
DSP  DSP                DSPWARE CURR  BOOT                        PAK    TX/RX
TYPE NUM CH CODEC      VERSION STATE STATE  RST AI VOICEPORT TS ABORT  PACK COUNT
C549 001 01 g729r8      24.3.0 busy  idle      0  0 1/0/0:1  01    0 38027464/319
        63465
        02 g729r8      24.3.0 busy  idle        0 1/0/0:1  02    0 39277870/332
        68142
        03 g729r8      24.3.0 busy  idle        0 1/0/0:1  03    0 46455212/518
        28885
        04 g729r8      24.3.0 busy  idle        0 1/0/0:1  04    0 39306088/330
        62784
C549 002 01 g729r8      24.3.0 busy  idle      0  0 1/0/0:1  05    0 37955137/318
        10363
        02 g729r8      24.3.0 busy  idle        0 1/0/0:1  06    0 38934740/336
        20268
        03      24.3.0 IDLE  idle        0 1/0/0:1  08    0 39566673/340
        45348
C549 003 01      24.3.0 IDLE  idle        0 1/0/0:1  10    0 36546649/318
        64490
        03 g729r8      24.3.0 busy  idle        0 1/0/0:1  11    0 36729606/311
        18894
        04 g729r8      24.3.0 busy  idle        0 1/0/0:1  12    0 37703120/321
        38912
C549 004 01 g729r8      24.3.0 busy  idle      0  0 1/0/0:1  13    0 47982248/523
        21531
        02 None        24.3.0 busy  idle        0 1/0/0:1  14    0 37342855/324
        84111
        03 g729r8      24.3.0 busy  idle        0 1/0/0:1  15    0 38138464/326
        17185
        04 g729r8      24.3.0 busy  idle        0 1/0/0:1  16    0 38018485/327
        32490
C549 005 01 g729r8      24.3.0 busy  idle      0  0 1/0/0:1  17    0 39256003/337
        46054
        02 g729r8      24.3.0 busy  idle        0 1/0/0:1  18    0 37141048/317
        39223
        03 None        24.3.0 busy  idle        0 1/0/0:1  19    0 37672795/322
        37939
        04      24.3.0 IDLE  idle      0  0 1/0/0:1  21    0 38377255/323
        95308
        02      24.3.0 IDLE  idle        0 1/0/0:1  23    0 39896264/335
        99060
        04      24.3.0 IDLE  idle        0 1/0/0:1  24    0 38007548/321
        71795
Best Regards!
You need to use 'sh voice dsp detail' to see all the DSPs in that command.
You can also use 'sh voice dsp group all' to leverage some DSP information on what the DSPs are provisioned for.
Hi, Sir :
Show voice dsp detailed always only show only 24 channel for DSP C549 and show voice dsp group all that the command cann't support for C549 and cann't display the detail for the C549.
In addition I have two voice card VWIC2-1MFT-T1/E1 on Slot 0 SubSlot 1 and on VWIC-1MFT-T1= Slot 1 SubSlot 0,for more detailed information as the output of show inventory.
NAME: "T1 (1 Port) Multi-Flex Trunk WAN Daughter Card on Slot 1 SubSlot 0", DESCR: "T1 (1 Port) Multi-Flex Trunk WAN Daughter Card"
PID: VWIC-1MFT-T1= , VID: 1.0, SN: 30618128
Why are you using cna VWIC in an NM slot ?
Can't you place it directly in an HWIC slot ?
Hi, Sir :
For the output of commond on show voice dsp group all that I also have another confused: one calling used the codec g729r8 must be two or three channel, why one dsp channel matched one call as the output?
Wj_F1_1# show voice dsp group all
DSP groups on slot 0:
dsp 13:
State: UP, firmware: 24.3.0
Max signal/voice channel: 16/16
Max credits: 240
num_of_sig_chnls_allocated: 16
Transcoding channels allocated: 0
Group: FLEX_GROUP_VOICE, complexity: FLEX
Shared credits: 120, reserved credits: 0
Signaling channels allocated: 16
Voice channels allocated: 4
Credits used: 120
Voice channels:
Ch01: voice port: 0/1/0:1.19, codec: g729r8, credits allocated: 30
Ch02: voice port: 0/1/0:1.11, codec: g729r8, credits allocated: 30
Ch03: voice port: 0/1/0:1.20, codec: g729r8, credits allocated: 30
Ch05: voice port: 0/1/0:1.12, codec: g729r8, credits allocated: 30
dsp 14:
Max credits: 240
num_of_sig_chnls_allocated: 8
Shared credits: 150, reserved credits: 0
Signaling channels allocated: 8
Voice channels allocated: 3
Credits used: 90
Voice channels:
Ch01: voice port: 0/1/0:1.3, codec: g729r8, credits allocated: 30
Ch02: voice port: 0/1/0:1.21, codec: g729r8, credits allocated: 30
Ch03: voice port: 0/1/0:1.22, codec: g729r8, credits allocated: 30
Hi, Sir :
Can you give futher advise?
