Numbering rules within an Access List
Answered Question
Sep 2nd, 2010
I'm creating several extended access lists and I want each rule within the access list to have a number, so that it can be individually deleted without having to delete the entire access list.  I'm using a 2821 router and can't find anyway to do this.  Thank you for any assistance you can give.
Correct Answer by Jon Marshall about 6 years 4 months ago
[email protected]
Charles
2821(config)# ip access-list extended TPS
2821(config-ext-nacl)# 10  permit ip host 192.168.5.1 host 192.168.6.1
2821(config-ext-nacl)# 20 permit ip 192.168.5.0 0.0.0.255 host 17.16.5.1
etc...
note you don't have to use increments of 10 ie. in the above i have used 10, 20 for acl entries but it's usually enough as this gives you the flexibility to add lines in between.
Jon
Overall Rating: 5 (2 ratings)
Correct Answer
Jon Marshall Thu, 09/02/2010 - 13:30
[email protected]
Charles
etc...
Jon
charles.e.davis... Thu, 09/02/2010 - 13:37
Thanks for the help.  Is there any reason that the numbers don't show up in the configuration?
