WRV210 Port Forwarding not opening ports
Sep 2nd, 2010
Greetings,
I have a Linksys/Cisco WRV210 Wireless-G VPN  Router with RangeBooster.  ISP provides dynamic IP with all ports  open.  I have no equipment to interact with from them; they just provide  me a CAT5 cable out of the wall.  ISP -> WRV210 -> LAN
Router Stats
  Hardware Version: WRTR-221G_V1
  Software Version:  2.0.0.11
  Connection Type:  Automatic Configuration - DHCP
  IP Address: 10.1.222.104
  Subnet Mask: 255.255.255.0
  Default Gateway:  10.1.222.1
Port Forwarding 22152- 22152 192.168.1.152 Enabled
Port Triggering none
DMZ disabled
If I test within the LAN
nmap -p22152 192.168.1.152
Interesting ports on 192.168.1.152:
PORT      STATE SERVICE
22152/tcp open  unknown
If I test from outside the router (xxx and ### are just my masking edits)
nmap -p22152 desktop.dns.xxx
Interesting ports on ##.###.##.###:
PORT      STATE  SERVICE
22152/tcp closed unknown
If I test from inside the LAN directed at the router
Interesting ports on 192.168.1.1:
PORT      STATE  SERVICE
It would seem  the router is completely ignoring my Port Forwarding instructions.  I  have hard reset the router.  I have upgraded to the lastest firmware.   None of these has made a difference.
My last test was to see if any ports are open on the router
nmap 192.168.1.1
Not shown: 997 closed ports
PORT      STATE SERVICE
80/tcp    open  http
443/tcp   open  https
60443/tcp open  unknown
My questikon would be if anyone has a "trick" to activate port forwarding on the route?
Thank you.
