1142N unable to open Web GUI and CMD line options not available
Sep 2nd, 2010
I am currently trying to configure two 1142N APs (AIR-LAP1142N-A-K9) to be stand alone APs. I have followed the PDFs
http://www.cisco.com/en/US/customer/docs/wireless/access_point/12.3_8_JA/configuration/guide/s38frst.html#wp1103248
and
http://www.cisco.com/en/US/customer/docs/wireless/access_point/12.3_2_JA/configuration/guide/s32frst.html#wp1103310
I set up the switch to provide DHCP and confirmed that each AP is indeed assigned an IP address. I can also ping each device. However when trying to browse to the GUI it fails to connect. So I tried to configure it via the CMD line. The enable mode does not give the option to configure interfaces as you would expect in enable mode nor does it give the option to enter global exec. example of the out put below.
AP8843.e178.0ee0>
AP8843.e178.0ee0>enable
Password:
AP8843.e178.0ee0#?
Exec commands:
  cd               Change current directory
  clear            Reset functions
  clock            Manage the system clock
  crypto           Encryption related commands.
  debug            Debugging functions (see also 'undebug')
  delete           Delete a file
  dir              List files on a filesystem
  disable          Turn off privileged commands
  enable           Turn on privileged commands
  exit             Exit from the EXEC
  fsck             Fsck a filesystem
  help             Description of the interactive help system
  led              LED functions
  lock             Lock the terminal
  login            Log in as a particular user
  logout           Exit from the EXEC
  lwapp            lwapp exec commands
  mkdir            Create new directory
  monitor          Monitoring different system events
  more             Display the contents of a file
  name-connection  Name an existing network connection
  no               Disable debugging functions
  ping             Send echo messages
  pwd              Display current working directory
  release          Release a resource
  reload           Halt and perform a cold restart
  rename           Rename a file
  renew            Renew a resource
  rmdir            Remove existing directory
  send             Send a message to other tty lines
  set              Set system parameter (not config)
  show             Show running system information
  systat           Display information about terminal lines
  terminal         Set terminal line parameters
  test             Test subsystems, memory, and interfaces
  traceroute       Trace route to destination
  undebug          Disable debugging functions (see also 'debug')
  upgrade          Upgrade software
  verify           Verify a file
  where            List active connections
It seems that the IOS on this device does not have the capability to configure the AP as stand alone or that it has been disabled. How do I get into the CMD line to configure the AP for deployment?
Secondly since I could not configure it via the CMD line I attempted to connect to it via the GUI like I said above. This fails. I ran an NMAP to find out what is open and found that nothing but port 23 is open. What is the deal here? Is the web GUI shut off by default? Am I just totally missing something? I think I dies a little inside after this...help please?
Overall Rating: 4.5 (6 ratings)
jjohnson1980 Thu, 09/02/2010 - 14:57
AP8843.e178.0ee0#sh ver
Cisco IOS Software, C1140 Software (C1140-RCVK9W8-M), Version 12.4(18a)JA, RELEASE SOFTWARE (fc4)
Copyright (c) 1986-2008 by Cisco Systems, Inc.
Compiled Fri 21-Nov-08 01:28 by prod_rel_team
ROM: Bootstrap program is C1140 boot loader
BOOTLDR: C1140 Boot Loader (C1140-BOOT-M) Version 12.4(18a)JA3, RELEASE SOFTWARE (fc1)
AP8843.e178.0ee0 uptime is 2 hours, 16 minutes
System image file is "flash:/c1140-rcvk9w8-mx/c1140-rcvk9w8-mx"
A summary of U.S. laws governing Cisco cryptographic products may be found at:
[email protected].
cisco AIR-LAP1142N-A-K9    (PowerPC405ex) processor (revision B0) with 98294K/32768K bytes of memory.
Processor board ID
PowerPC405ex CPU at 586Mhz, revision number 0x147E
Last reset from power-on
LWAPP image version 3.0.51.0
1 Gigabit Ethernet interface
32K bytes of flash-simulated non-volatile configuration memory.
Base ethernet MAC Address:
Part Number                          :
PCA Assembly Number                  :
PCA Revision Number                  : A0
PCB Serial Number                    :
Top Assembly Part Number             :
Top Assembly Serial Number           :
Top Revision Number                  : A0
Product/Model Number                 : AIR-LAP1142N-A-K9
Configuration register is 0xF
Leo Laohoo Thu, 09/02/2010 - 15:17
  • Hall of Fame,
    The Hall of Fame designation is a lifetime achievement award based on significant overall achievements in the community.
  • Cisco Designated VIP,
    2017 LAN, Wireless
This is the culprit.  You are running a controller-based image.  In order to run an autonomous IOS, please use the procedure below.  Make sure you also have the correct autonomous IOS.
Using a TFTP Server to Return to a Previous Release
http://www.cisco.com/en/US/docs/wireless/access_point/conversion/lwapp/upgrade/guide/lwapnote.html#wp160918
Please don't forget to rate our useful posts.  Thanks.
jjohnson1980 Thu, 09/02/2010 - 15:26
Thanks very much, even more points for giving the link on how to change the image!
sbyrappa Sun, 01/22/2012 - 09:57
  • Cisco Employee,
It worked Well for Me too..
Related Content
