Trying to set up a VPN
Answered Question
I thought an SSL VPN would be good but everytime I go to connect to it I have click through security warnings and install a securty certificate. Other than that the VPN works, however there will be less tech savy (and paitent) users using this vpn, and they will not want to have to click through a bunch of security warnings to get to the VPN. So is there a way I can have the user connect to a web portal once and that will download the VPN any connect software on thier computer then after that all they have to do is open the any connect software and type in a username and password and preferably have the vpn software remember the ip address for them? Also if this could be done via CCP that would be great, I'm new to Cisco routers and don't know the command line yet. If it can't be done via ccp then I guess I'll have to bite the bullet and do it via command line. Thanks.
Correct Answer by Yudong Wu about 6 years 7 months ago
The problem is that you configured to use keypair "test" in the trustpoint but you did not generate the key with label "test".
Please following the extactly steps below.
1. generate a key with name "test"
crypto key generate rsa modulus 1024 label test
2. remove "ip domain name" If it is configured
no ip domain name xxxx.xxx
3. configure your trustpoint like following
crypto pki trustpoint self-signed
enrollment selfsigned
fqdn
subject-name CN=
rsakeypair test
4. change your host name to IP address.
hostname
5. crypto pki enroll self-signed
6. change your hostname back to its previous name.
7. add "ip domain name" back
8. change webvpn config to point to the new trustpoint
webvpn gateway gateway_1
ssl trustpoint self-signed
Then try the webvpn by using your public IP.
Overall Rating: 5 (2 ratings)
Yudong Wu Thu, 09/02/2010 - 21:20
  • Gold, 750 points or more
On the SSL VPN client, you need install the certificate of root CA which issued the certificate to your SSL VPN Router/ASA. The root CA should be in the trusted list as well in your client's computer.
What do you mean by on the ssl client I have to install a certificate? When I access the vpn web portal through the ip address I get to a page where I type in a username and password then form there I go to a Cisco SSL VPN service page I click on the start button by tunnel connection then I get a whole bunch of certificate warnings then I get a screen that asks me to install the certificate. I do that and then I am able to connect to the vpn. But this happens everytime I need to connect to the VPN. I've seen cisco VPNs where I just open up the Anyconnect cliet on my computer and choose the ip from a drop down list then it asks me for a user name and password once I enter those I am connected to the vpn with no hassel.
Yudong Wu Fri, 09/03/2010 - 08:03
could you please post your configuration file here?
Building configuration...
Current configuration : 13425 bytes
! Last configuration change at 08:32:26 PCTime Fri Sep 3 2010 by administrator
! NVRAM config last updated at 16:47:39 PCTime Thu Sep 2 2010 by administrator
version 12.4
no service pad
service tcp-keepalives-in
service tcp-keepalives-out
service timestamps debug datetime msec localtime show-timezone
service timestamps log datetime msec localtime show-timezone
service password-encryption
service sequence-numbers
hostname *name*
boot-start-marker
boot-end-marker
security authentication failure rate 3 log
security passwords min-length 6
logging buffered 51200
logging console critical
enable secret 5 *password*
aaa new-model
aaa authentication login default local
aaa authentication login ciscocp_vpn_xauth_ml_1 local
aaa authentication login ciscocp_vpn_xauth_ml_2 local
aaa authorization exec default local
aaa authorization network ciscocp_vpn_group_ml_1 local
aaa session-id common
clock timezone PCTime -7
clock summer-time PCTime date Apr 6 2003 2:00 Oct 26 2003 2:00
crypto pki trustpoint TP-self-signed-4112746227
subject-name cn=IOS-Self-Signed-Certificate-4112746227
revocation-check none
rsakeypair TP-self-signed-4112746227
crypto pki certificate chain TP-self-signed-4112746227
certificate self-signed 01
  3082024F 308201B8 A0030201 02020101 300D0609 2A864886 F70D0101 04050030
  31312F30 2D060355 04031326 494F532D 53656C66 2D536967 6E65642D 43657274
  69666963 6174652D 34313132 37343632 3237301E 170D3130 30383234 31373234
  33325A17 0D323030 31303130 30303030 305A3031 312F302D 06035504 03132649
  4F532D53 656C662D 5369676E 65642D43 65727469 66696361 74652D34 31313237
  34363232 3730819F 300D0609 2A864886 F70D0101 01050003 818D0030 81890281
  8100E019 5ECA9061 1B264BA9 00CB9644 F55859F7 E8B62916 11FF750C C1F84F99
  BB531024 D90BDF1A C4FE5841 7FC2F512 4B62F7B9 455C58D8 DFF4EE80 42EB09AE
  50BF3B90 275BF68D 01D18313 CE3BC743 E0BA0AED F1DC5214 2F2DB892 B3877BCC
  0668D120 499FE43A C54B0E79 39459CAD 8C5ADB85 29F24C6B 1C2C06E3 47DC26DC
  42450203 010001A3 77307530 0F060355 1D130101 FF040530 030101FF 30220603
  551D1104 1B301982 17796F75 726E616D 652E796F 7572646F 6D61696E 2E636F6D
  301F0603 551D2304 18301680 149F4E46 8DB29BD6 9657D5DD D700A6F8 DC4D7E28
  9D301D06 03551D0E 04160414 9F4E468D B29BD696 57D5DDD7 00A6F8DC 4D7E289D
  300D0609 2A864886 F70D0101 04050003 8181000A 7A1FC97B 3261F4DC 226ECC63
  890E13D2 29DD0398 2C335CAA A8D4ABFF 4D9E4927 70813327 0A940859 9D87F4EA
  F9F016E1 258ACBC2 F68EA255 045D0976 9F01B97C 8FBCC4B6 84835922 3F069EE8
  14353DF2 9CF5AF42 A905777A 9220089E E4FD59B9 40ADD114 0878EBA1 A0997B04
  3288FD2F 1710878A 4A20C8EC 549A0BE1 EB164B
      quit
dot11 syslog
no ip source-route
ip cef
no ip dhcp use vrf connected
ip dhcp excluded-address 10.11.100.1 10.11.100.99
ip dhcp pool ccp-pool1
   import all
   network 10.11.100.0 255.255.255.0
   default-router 10.11.100.1
no ip bootp server
no ip domain lookup
ip domain name yourdomain.com
username *name* privilege 15 secret 5 *password*
username *name* privilege 7 secret 5 *password*
crypto isakmp policy 1
encr 3des
authentication pre-share
group 2
crypto isakmp key *password* address *ip address*
crypto isakmp key *password* address *ip address 2*
crypto isakmp client configuration group *group name*
key *Password*
pool *name*
crypto isakmp profile ciscocp-ike-profile-1
   match identity group *group name*
   client authentication list ciscocp_vpn_xauth_ml_2
   isakmp authorization list ciscocp_vpn_group_ml_1
   client configuration address respond
   virtual-template 1
crypto ipsec transform-set ESP-3DES-SHA esp-3des esp-sha-hmac
crypto ipsec transform-set ESP-3DES-SHA1 esp-3des esp-sha-hmac
crypto ipsec transform-set ESP-3DES-SHA2 esp-3des esp-sha-hmac
crypto ipsec profile CiscoCP_Profile1
set transform-set ESP-3DES-SHA2
set isakmp-profile ciscocp-ike-profile-1
crypto map SDM_CMAP_1 1 ipsec-isakmp
description Tunnel to*ip address*
set peer *ip address*
match address 102
crypto map SDM_CMAP_2 1 ipsec-isakmp
description Tunnel to*ip address 2*
set peer *ip address 2*
set transform-set ESP-3DES-SHA1
match address 106
archive
log config
  hidekeys
ip tcp synwait-time 10
ip ssh time-out 60
ip ssh authentication-retries 2
class-map type inspect match-all sdm-cls-VPNOutsideToInside-1
match access-group 104
class-map type inspect match-all sdm-cls-VPNOutsideToInside-2
match access-group 107
class-map type inspect match-any SDM_AH
match access-group name SDM_AH
class-map type inspect match-any SDM_WEBVPN
match access-group name SDM_WEBVPN
class-map type inspect match-all SDM_WEBVPN_TRAFFIC
match class-map SDM_WEBVPN
match access-group 101
class-map type inspect match-any SDM_ESP
match access-group name SDM_ESP
class-map type inspect match-any SDM_VPN_TRAFFIC
match protocol isakmp
match protocol ipsec-msft
match class-map SDM_AH
match class-map SDM_ESP
class-map type inspect match-all SDM_VPN_PT
match access-group 103
match class-map SDM_VPN_TRAFFIC
class-map type inspect match-any ccp-cls-insp-traffic
match protocol cuseeme
match protocol dns
match protocol ftp
match protocol h323
match protocol https
match protocol icmp
match protocol imap
match protocol pop3
match protocol netshow
match protocol shell
match protocol realmedia
match protocol rtsp
match protocol smtp extended
match protocol sql-net
match protocol streamworks
match protocol tftp
match protocol vdolive
match protocol tcp
match protocol udp
class-map type inspect match-all ccp-insp-traffic
match class-map ccp-cls-insp-traffic
class-map type inspect match-any SDM_IP
match access-group name SDM_IP
class-map type inspect match-any SDM_EASY_VPN_SERVER_TRAFFIC
class-map type inspect match-all SDM_EASY_VPN_SERVER_PT
match class-map SDM_EASY_VPN_SERVER_TRAFFIC
class-map type inspect match-any ccp-cls-icmp-access
match protocol icmp
match protocol tcp
match protocol udp
class-map type inspect match-all ccp-invalid-src
match access-group 100
class-map type inspect match-all ccp-icmp-access
match class-map ccp-cls-icmp-access
class-map type inspect match-all ccp-protocol-http
match protocol http
policy-map type inspect ccp-permit-icmpreply
class type inspect ccp-icmp-access
  inspect
class class-default
  pass
policy-map type inspect sdm-pol-VPNOutsideToInside-1
class type inspect sdm-cls-VPNOutsideToInside-1
  inspect
class type inspect sdm-cls-VPNOutsideToInside-2
  inspect
class class-default
policy-map type inspect ccp-inspect
class type inspect ccp-invalid-src
  drop log
class type inspect ccp-protocol-http
  inspect
class type inspect ccp-insp-traffic
  inspect
class class-default
class type inspect SDM_EASY_VPN_SERVER_PT
  pass
class type inspect SDM_VPN_PT
  pass
class type inspect SDM_WEBVPN_TRAFFIC
  inspect
class class-default
policy-map type inspect sdm-permit-ip
class type inspect SDM_IP
  pass
class class-default
  drop log
zone security out-zone
zone security in-zone
zone security ezvpn-zone
zone-pair security ccp-zp-self-out source self destination out-zone
service-policy type inspect ccp-permit-icmpreply
zone-pair security ccp-zp-in-out source in-zone destination out-zone
service-policy type inspect ccp-inspect
zone-pair security ccp-zp-out-self source out-zone destination self
zone-pair security sdm-zp-VPNOutsideToInside-1 source out-zone destination in-zone
service-policy type inspect sdm-pol-VPNOutsideToInside-1
zone-pair security sdm-zp-in-ezvpn1 source in-zone destination ezvpn-zone
service-policy type inspect sdm-permit-ip
zone-pair security sdm-zp-out-ezpn1 source out-zone destination ezvpn-zone
zone-pair security sdm-zp-ezvpn-out1 source ezvpn-zone destination out-zone
zone-pair security sdm-zp-ezvpn-in1 source ezvpn-zone destination in-zone
interface FastEthernet0
description $ES_WAN$$FW_OUTSIDE$$ETH-WAN$
ip address dhcp client-id FastEthernet0
no ip redirects
no ip unreachables
no ip proxy-arp
ip nat outside
ip virtual-reassembly
zone-member security out-zone
ip route-cache flow
duplex auto
speed auto
interface FastEthernet1
no ip address
no ip redirects
no ip unreachables
no ip proxy-arp
ip route-cache flow
shutdown
duplex auto
speed auto
interface FastEthernet2
interface FastEthernet3
interface FastEthernet4
interface FastEthernet5
interface FastEthernet6
interface FastEthernet7
interface FastEthernet8
interface FastEthernet9
interface Virtual-Template1 type tunnel
ip unnumbered FastEthernet0
zone-member security ezvpn-zone
tunnel mode ipsec ipv4
tunnel protection ipsec profile CiscoCP_Profile1
interface Vlan1
description $ETH-SW-LAUNCH$$INTF-INFO-FE 2$$ES_LAN$$FW_INSIDE$
ip address 10.11.100.1 255.255.255.0
no ip redirects
no ip unreachables
no ip proxy-arp
ip nat inside
zone-member security in-zone
ip route-cache flow
ip tcp adjust-mss 1452
interface Async1
no ip address
no ip redirects
no ip unreachables
no ip proxy-arp
encapsulation slip
ip local pool *name* 10.11.100.50 10.11.100.99
ip forward-protocol nd
ip http server
ip http access-class 23
ip http authentication local
ip http secure-server
ip http timeout-policy idle 60 life 86400 requests 10000
ip nat inside source route-map SDM_RMAP_1 interface FastEthernet0 overload
ip access-list extended SDM_AH
remark CCP_ACL Category=1
permit ahp any any
ip access-list extended SDM_ESP
permit esp any any
ip access-list extended SDM_IP
permit ip any any
ip access-list extended SDM_WEBVPN
permit tcp any any eq 443
logging trap debugging
access-list 1 remark INSIDE_IF=Vlan1
access-list 1 remark CCP_ACL Category=2
access-list 1 permit 10.11.100.0 0.0.0.255
access-list 100 remark CCP_ACL Category=128
access-list 100 permit ip host 255.255.255.255 any
access-list 100 permit ip 127.0.0.0 0.255.255.255 any
access-list 101 remark CCP_ACL Category=128
access-list 101 permit ip any host *ip address*
access-list 102 remark CCP_ACL Category=4
access-list 102 remark IPSec Rule
access-list 102 permit ip 10.11.100.0 0.0.0.255 10.11.101.0 0.0.0.255
access-list 103 remark CCP_ACL Category=128
access-list 103 permit ip host *ip address* any
access-list 103 permit ip host *ip address 2* any
access-list 104 remark CCP_ACL Category=0
access-list 104 remark IPSec Rule
access-list 104 permit ip 10.11.101.0 0.0.0.255 10.11.100.0 0.0.0.255
access-list 105 remark CCP_ACL Category=2
access-list 105 remark IPSec Rule
access-list 105 deny   ip 10.11.100.0 0.0.0.255 10.11.100.0 0.0.0.255
access-list 105 deny   ip 10.11.100.0 0.0.0.255 10.11.101.0 0.0.0.255
access-list 105 permit ip 10.11.100.0 0.0.0.255 any
access-list 106 remark CCP_ACL Category=4
access-list 106 remark IPSec Rule
access-list 106 permit ip 10.11.100.0 0.0.0.255 10.11.100.0 0.0.0.255
access-list 107 remark CCP_ACL Category=0
access-list 107 remark IPSec Rule
access-list 107 permit ip 10.11.100.0 0.0.0.255 10.11.100.0 0.0.0.255
no cdp run
route-map SDM_RMAP_1 permit 1
match ip address 105
control-plane
banner exec ^C
% Password expiration warning.
Cisco Configuration Professional (Cisco CP) is installed on this device
and it provides the default username "cisco" for  one-time use. If you have
already used the username "cisco" to login to the router and your IOS image
supports the "one-time" user option, then this username has already expired.
You will not be able to login to the router with this username after you exit
this session.
It is strongly suggested that you create a new username with a privilege level
of 15 using the following command.
username privilege 15 secret 0
Replace and with the username and password you want to
use.
^C
banner login ^CAuthorized access only!
Disconnect IMMEDIATELY if you are not an authorized user!^C
line con 0
transport output telnet
line 1
modem InOut
stopbits 1
speed 115200
flowcontrol hardware
line aux 0
line vty 0 4
transport input telnet ssh
line vty 5 15
scheduler allocate 4000 1000
scheduler interval 500
ip address *ip address* port 443
http-redirect port 80
ssl trustpoint TP-self-signed-4112746227
inservice
webvpn install svc flash:/webvpn/svc.pkg
webvpn context *name*
secondary-color white
title-color #CCCC66
text-color black
ssl authenticate verify all
policy group policy_1
   functions svc-enabled
   svc address-pool "*name*"
   svc keep-client-installed
default-group-policy policy_1
aaa authentication list ciscocp_vpn_xauth_ml_1
gateway gateway_1
inservice
end
Ok I must be missing something here. Because here are the steps I followed:
Step 1 Go to Tools | Internet Options | Trusted Sites.
The Internet Options window opens.
Step 2 Click the Security tab.
Step 3 Click the Trusted Sites icon.
Step 4 Click Sites.
The Trusted Sites window opens.
Step 5 Type  the host name or IP address of the security appliance. Use a wildcard  such as https://*.yourcompany.com to allow all ASA 5500s within the  yourcompany.com domain to be used to support multiple sites.
Step 6 Click Add.
Step 7 Click OK.
The Trusted Sites window closes.
Step 8 Click OK in the Internet Options window.
And
Step 1 Click View Certificate in the Security Alert window.
The Certificate window opens.
Step 2 Click Install Certificate.
The Certificate Import Wizard Welcome opens.
Step 3 Click Next.
The Certificate Import Wizard - Certificate Store window opens.
Step 4 Select "Automatically select the certificate store based on the type of certificate."
Step 5 Click Next.
The Certificate Import Wizard - Completing window opens.
Step 6 Click Finish.
Step 7 Another Security Warning window prompts "Do you want to install this certificate?" Click Yes.
The Certificate Import Wizard window indicates the import is successful.
Step 8 Click OK to close this window.
Step 9 Click OK to close the Certificate window.
Step 10 Click Yes to close the Security Alert window.
The security appliance window opens, signifying the certificate is trusted.
But the next time I open the web portal I have to install the certificate again
And when I try to connect via anny connect (without going through the web portal) I get The security alert box, go through the steps to install a certificate, but thenm I get the error unable to process response from *host ip address*
Yudong Wu Sat, 09/04/2010 - 08:01
I think the issue might be related to self-signed certificate here.
I will run a lab testing on this when I get chance.
Yudong Wu Wed, 09/08/2010 - 11:31
Ok, I did not forget your question and ran a quick lab testing on this.
So basically the issue is related to your self-signed certificate.
Here is what I did.
1. Generate the self-signed certificate like the following
fqdn hostname.test.com
subject-name CN=hostname.test.com
rsakeypair test
Then, crypto pki enroll self-signed
2. When you access WebVPN, you must use "hostname.test.com" instead of IP address. In this way, after you install the certificate, it won't popup any alert message anymore.
3. You can add "svc keep-client-installed" in your policy. The the user can lauch the client from start->all program->Cisco->Cisco AnyConnect VPN client.
Yudong Wu Wed, 09/08/2010 - 11:44
It's not necessary.
I think the client will check the "subject name" in your certificate with the hostname in your URL or "connect to" box. If they don't match, you will see those popup alert message.
So, if you add an entry in host file of your client's PC/laptop, it should work. That's how I did the testing.
You can probably play with the trustpoint configuration to see if you can put ip address in the subject-name.  Let me try this to see how it works.
Yudong Wu Wed, 09/08/2010 - 12:42
Ok, here is steps if you would like to use IP address instead of dns name.
1. remove "ip domain name "
2. configure your trustpoint like following
fqdn 172.16.182.87
subject-name CN=172.16.182.87
rsakeypair test
3. change your host name to IP address. "hostname 172.16.182.87"
4. crypto pki enroll self-signed
5. change your hostname back to its previous name.
6. add "ip domain name"
After above steps, you can use IP to connect to webvpn without those cert popup windows after you install the cert.
How would I edit the certificate. in CCP I go to security->vpn->vpn components->public key infrastructure->certificate authority server then click on router certificates then I see test_trustpoint_conf and tp-self-signed-411; neither of which I can edit. I can delete them, but I don't think I want to do that as I've done it beofre and the router wouldn't function anymore, I had to completely restore the factory settings before the router would work again.
Yudong Wu Thu, 09/09/2010 - 10:41
Sorry, I don't use CCP and am not sure how to use it to configure the self-signed cert.
You can use the command line per you previous post..
You can try to add a new trustpoint by using CCP to see if you can specify the related parameter as what I mentioned in the previous post.
Yudong Wu Thu, 09/09/2010 - 22:53
Well, you might need to read the config guide and command ref if you would like to learn how to use command line.
Yudong Wu Fri, 09/10/2010 - 08:38
Ok, this is the only link which I found on CCO about using CCP to configure Anyconnect on the router.
http://www.cisco.com/en/US/products/ps5855/products_configuration_example09186a0080af314a.shtml
But it does not inclued info of generating certificate. If you would like to get rid of those certifcate popup windows, you have to generate the self-signed certificate like what I mentioned before. Sorry, I never play with CCP before. But it should be doable on CCP as well.
Yudong Wu Fri, 09/10/2010 - 13:17
Yes, that's the public IP address which you got from your ISP.
Anyconnect client will use it to connect to your router.
Do you have a static public IP? I saw your router is configured as DHCP client.
Yudong Wu Fri, 09/10/2010 - 22:27
What trustpoint name did you configured in step 2?
You need use the same trustpoint name in "crypto pki enroll "
You need check the following configuration as well to use the same trustpoint name which you configured in step 2.
ssl trustpoint TP-self-signed-4112746227  <<<<< Replace "TP-self-signed-4112746227" with new trustpoint name.
here are the exact steps I followed:
I changed the host name from yourdomain.com to *external IP address*
(TP-self-signed-4112746277 was already there, I guess that is the one that CCP created, so I just wanted to edit that one)
fqdn *external IP Address*
subject-name CN=*external IP address*
rsakeypair test
crypto pki enroll self-signed rypto pki enroll TP-self-signed-4112746227
That's when I get the error. Alos now i don't seem to have nay vpn access. when I go to https://*external ip address* I get a page cannot be displayed error.
Yudong Wu Mon, 09/13/2010 - 08:31
Can you send me the following output?
show crypto ca cert
show crypto key mypub rsa
show run
Show Crypto ca cert:
Router Self-Signed Certificate
  Status: Available
  Certificate Serial Number: 0x2
  Certificate Usage: General Purpose
  Issuer:
  Subject:
  Validity Date:
    start date: 14:15:27 PCTime Sep 10 2010
    end   date: 17:00:00 PCTime Dec 31 2019
  Associated Trustpoints: TP-self-signed-4112746227
  Storage: nvram:IOS-Self-Sig#8.cer
Show crypto key mypub rsa:
% Key pair was generated at: 15:33:19 PCTime Jun 9 2010
Key name: TP-self-signed-4112746227
Storage Device: private-config
Usage: General Purpose Key
Key is not exportable.
Key Data:
  30819F30 0D06092A 864886F7 0D010101 05000381 8D003081 89028181 00E0195E
  CA90611B 264BA900 CB9644F5 5859F7E8 B6291611 FF750CC1 F84F99BB 531024D9
  0BDF1AC4 FE58417F C2F5124B 62F7B945 5C58D8DF F4EE8042 EB09AE50 BF3B9027
  5BF68D01 D18313CE 3BC743E0 BA0AEDF1 DC52142F 2DB892B3 877BCC06 68D12049
  9FE43AC5 4B0E7939 459CAD8C 5ADB8529 F24C6B1C 2C06E347 DC26DC42 45020301 0001
% Key pair was generated at: 14:44:41 PCTime Sep 10 2010
Key name: HTTPS_SS_CERT_KEYPAIR
Key Data:
  307C300D 06092A86 4886F70D 01010105 00036B00 30680261 0096B970 35F7601D
  5274FE99 104D332A C184E1B8 7B6E80DB F021329A 4060E954 73BD204D E7D1BC8A
  F7B970D7 C8641C3F 0FB1C343 3FBB92AD AFC8077A 74DAE087 65365BE2 C9EAD501
  6D4B606D 16F4F69A 95E3E11C A75DE920 CA733FAC E6024DE1 51020301 0001
% Key pair was generated at: 11:00:11 PCTime Sep 13 2010
Key name: TP-self-signed-4112746227.server
Temporary key
Usage: Encryption Key
Key Data:
  307C300D 06092A86 4886F70D 01010105 00036B00 30680261 00E0F3E5 188FF4A3
  43B34598 BF62BBFA 839B6511 529DB9C2 7B71EAD3 EAF6D5FA 595C3601 360CD573
  4AA3B205 025FA0E7 633BC1A6 C3C34CE9 92D37B8E F2DD3C0D 4DD4FD3A 9CB18FAF
  1EF79244 03490CB8 C148A736 37879D87 D1C57580 FE8B3136 49020301 0001
show run:
Current configuration : 15678 bytes
version 12.4
no service pad
hostname *host name*
boot-start-marker
boot-end-marker
enable secret *password*
aaa new-model
crypto pki trustpoint test_trustpoint_config_created_for_sdm
subject-name [email protected]
revocation-check crl
fqdn *external ip address*
subject-name CN=*external ip address*
rsakeypair test
crypto pki trustpoint tp-self-signed-4112746277
rsakeypair test
crypto pki certificate chain test_trustpoint_config_created_for_sdm
certificate self-signed 02
  30820257 308201C0 A0030201 02020102 300D0609 2A864886 F70D0101 04050030
  69666963 6174652D 34313132 37343632 3237301E 170D3130 30393130 32313135
  32375A17 0D323030 31303130 30303030 305A3031 312F302D 06035504 03132649
  42450203 010001A3 7F307D30 0F060355 1D130101 FF040530 030101FF 302A0603
  551D1104 23302182 1F4C6574 68627269 6467655F 53434144 412E796F 7572646F
  6D61696E 2E636F6D 301F0603 551D2304 18301680 149F4E46 8DB29BD6 9657D5DD
  D700A6F8 DC4D7E28 9D301D06 03551D0E 04160414 9F4E468D B29BD696 57D5DDD7
  00A6F8DC 4D7E289D 300D0609 2A864886 F70D0101 04050003 81810050 8CA99031
  63FDE47E 1211CABE F928262D 0B5A0F98 5E0AC93D 3E66CDCF 1E0C376F 3ED388E8
  A1278120 46022932 DB449A54 7EA9138F 47478F6A AFDCA706 F3E9206E 718F668C
  1605681B B77BA23B 1B9DD266 FCC57E97 EE835F5B 60546C0C 12E0BB4B D72600E0
  ED01F4DB B6880EA6 246C4502 73CCAB49 7787CB05 BC38D2CC 78FD41
                quit
crypto pki certificate chain tp-self-signed-4112746277
dot11 syslog
no ip source-route
ip cef
   import all
no ip bootp server
ip domain name *external ip address*
username administrator privilege 15 secret *password*
username VPNuser privilege 7 secret 5 *password*
encr 3des
group 2
crypto isakmp key Cisco1811VPN address *external ip address 2*
crypto isakmp key Cisco1811VPN address *external ip address 3*
crypto isakmp client configuration group VPN_users
key *shared key*
pool VPN_Pool
   match identity group VPN_users
   virtual-template 1
description Tunnel to*external ip address 2*
set peer *external ip address 2*
match address 102
description Tunnel to*external ip address 3*
set peer *external ip address 3*
match address 106
archive
log config
  hidekeys
ip ssh time-out 60
class-map type inspect match-any SDM_BOOTPC
match access-group name SDM_BOOTPC
class-map type inspect match-all sdm-cls-VPNOutsideToInside-3
match access-group 109
class-map type inspect match-all sdm-cls-VPNOutsideToInside-4
match access-group 110
class-map type inspect match-any SDM_DHCP_CLIENT_PT
match class-map SDM_BOOTPC
class-map type inspect match-all SDM_GRE
match access-group name SDM_GRE
class-map type inspect match-any CCP_PPTP
match class-map SDM_GRE
class-map type inspect match-any ccp-skinny-inspect
match protocol skinny
class-map type inspect match-any sdm-cls-bootps
match protocol bootps
match protocol pptp
match protocol dns
match protocol ftp
match protocol icmp
match protocol imap
match protocol pop3
match protocol rtsp
match protocol tftp
match protocol tcp
match protocol udp
class-map type inspect match-all SDM_VPN_PT0
match access-group 108
match protocol icmp
match protocol tcp
match protocol udp
class-map type inspect match-any ccp-h225ras-inspect
match protocol h225ras
class-map type inspect match-any ccp-h323-inspect
match protocol h323
class-map type inspect match-all ccp-cls-sdm-permit-ip-1
match access-group name VNC
class-map type inspect match-any ccp-sip-inspect
match protocol sip
match protocol http
class type inspect sdm-cls-bootps
  pass
  inspect
class class-default
  pass
  inspect
  inspect
class type inspect sdm-cls-VPNOutsideToInside-3
  inspect
class type inspect CCP_PPTP
  pass
class type inspect sdm-cls-VPNOutsideToInside-4
  inspect
class class-default
  drop log
  drop log
  inspect
  inspect
class type inspect ccp-h323-inspect
  inspect
class type inspect ccp-h225ras-inspect
  inspect
class class-default
class type inspect SDM_VPN_PT0
  pass
  pass
class type inspect SDM_DHCP_CLIENT_PT
  pass
class class-default
  pass
  inspect
class class-default
  drop log
no ip redirects
no ip unreachables
no ip proxy-arp
ip nat outside
ip route-cache flow
duplex auto
speed auto
no ip address
no ip redirects
no ip unreachables
no ip proxy-arp
ip route-cache flow
shutdown
duplex auto
speed auto
interface Vlan1
no ip redirects
no ip unreachables
no ip proxy-arp
ip nat inside
ip route-cache flow
interface Async1
no ip address
no ip redirects
no ip unreachables
no ip proxy-arp
encapsulation slip
ip local pool VPN_Pool10.11.100.50 10.11.100.99
ip http server
permit ahp any any
ip access-list extended SDM_BOOTPC
permit udp any any eq bootpc
permit esp any any
ip access-list extended SDM_GRE
permit gre any any
permit ip any any
ip access-list extended VNC
permit ip any host 10.11.100.101
access-list 101 permit ip any host *external ip address*
access-list 103 permit ip host *external ip address 2* any
access-list 103 permit ip host *external ip address 3* any
access-list 108 remark CCP_ACL Category=128
access-list 108 permit ip host *external ip address 3* any
access-list 109 remark CCP_ACL Category=0
access-list 109 remark IPSec Rule
access-list 109 permit ip 10.11.100.0 0.0.0.255 10.11.100.0 0.0.0.255
access-list 110 remark CCP_ACL Category=0
access-list 110 remark IPSec Rule
access-list 110 permit ip 10.11.100.0 0.0.0.255 10.11.100.0 0.0.0.255
no cdp run
control-plane
banner exec ^C
this session.
use.
^C
line con 0
line 1
modem InOut
stopbits 1
speed 115200
line aux 0
line vty 0 4
line vty 5 15
ip address *external ip address* port 443
inservice
webvpn context VPN_Pool
title-color #CCCC66
text-color black
   svc address-pool "VPN_Pool"
gateway gateway_1
inservice
end
Correct Answer
Yudong Wu Mon, 09/13/2010 - 10:54
fqdn
subject-name CN=
rsakeypair test
hostname
I'm following your steps exactly but wehen I get to
hostname
I get an error that syas hostname contains illegal characters. There dosen't seem to be be any other errors so I continue on. I'm still not getting the web page when I type in the ip address, I'm still getting a page cannot be displayed error. Also the hostname and domain name are mixed up. The hostname is the external IP address and the domain name is Cisco_Router. Should it be this way?
Yudong Wu Mon, 09/13/2010 - 14:27
can you paste the following again?
show crypto ca cert
show run
Finally I got it! I deleted all the certificate and the gateway and started from scratch. The only problem now is the user still have to go through the web portal to connect, the VPN client stays on thier computer, but they can't use it to connect. But I think that is a problem for another day. It's now set up so that it will only ask them to install the certificate once, which is fine. Thank you so much for all your help and patience.
Yudong Wu Mon, 09/13/2010 - 14:46
Great!!!!
I am glad that you finally made it work.
After the first connection with web, did you try to  lauch the client from start->all program->Cisco->Cisco  AnyConnect VPN client directly without using web?
Yudong Wu Tue, 09/14/2010 - 09:45
What's your IOS version on the router?
show version
Cisco IOS Software, C181X Software (C181X-ADVIPSERVICESK9-M), Version 12.4(15)T1
0, RELEASE SOFTWARE (fc3)
Copyright (c) 1986-2009 by Cisco Systems, Inc.
Compiled Mon 14-Sep-09 20:59 by prod_rel_team
ROM: System Bootstrap, Version 12.3(8r)YH13, RELEASE SOFTWARE (fc1)
*host name* uptime is 19 hours, 46 minutes
System image file is "flash:c181x-advipservicesk9-mz.124-15.T10.bin"
A summary of U.S. laws governing Cisco cryptographic products may be found at:
[email protected].
Cisco 1811 (MPC8500) processor (revision 0x400) with 236544K/25600K bytes of mem
ory.
Processor board ID FHK134975HW, with hardware revision 0000
10 FastEthernet interfaces
1 Serial interface
1 terminal line
62720K bytes of ATA CompactFlash (Read/Write)
Yudong Wu Tue, 09/14/2010 - 10:22
I tested on "anyconnect-win-2.5.1025-k9.pkg" and "12.4(22)T3" and did not see the issue.
You can try upgrade the code to see if it can be fixed.
Antonio Knox Fri, 09/10/2010 - 06:03
  • Silver, 250 points or more
If I understand you correctly, this seems to be your main question:
"So is there a way I can have the user connect to a web portal once and  that will download the VPN any connect software on thier computer then  after that all they have to do is open the any connect software and type  in a username and password and preferably have the vpn software  remember the ip address for them?"
The answer is yes.  There are two ways to go about this......
Command Line:
group-policy AnyConnect attributes
webvpn
svc keep-installer installed
ASDM (I'm running Version 6.3):
Go to Configuration --> Remote Access VPN --> Group Policies --> Highlight Your-Group-Policy-Name --> Edit --> Expand 'Advanced' on the left --> Click SSL VPN Client --> In the 'Keep Installer on Client System' uncheck 'Inherit' and click the 'Yes' radio button  --> Click OK --> Click apply
from that point on, when a user connects to AnyConnect, the vpn client will remain on the users machine.  It will also remember the VPN gateway address when its run.  All they should have to do is locate the installer on their machine, run it, click connect, and enter their creds.  Hope that helps.
Please rate my post if its helpful.
Related Content
