ASA active standby failover if i used only one ip address on interface
Sep 2nd, 2010
for example, in outside interface used only active ip address not used standby ip address
but inside interface used both active and standby ip address?
Could this be the issue?
thank.
Nagaraja Thanthry Thu, 09/02/2010 - 19:27
  • Cisco Employee,
If you are short of IP addresses, you can certainly use IP address only on
the outside interface and not on the secondary (no standby). The only thing
will be that the standby interface would be in "waiting" status. While
outside interface does not have a standby address, you can configure the
inside interface with standby.
Hope this helps.
NT
