Lwapp AP and DHCP option 43
Answered Question
Sep 2nd, 2010
I have configured option 43 on dhcp server, rebooted 1131 AP, but AP always try to resolve CISCO-LWAPP-CONTROLLER instead of ip provided by dhcp. How can I debug this?
Config on router:
ip dhcp pool seg20
option 43 hex f104.0a0f.64fd
Thanx.
Correct Answer by Stephen Rodriguez about 6 years 10 months ago
A CUWN AP, goes through all methods of discovery.  So it always attempts to use DNS, option 43, L3 broadcast, L2 broadcast.  Once it has discovered, then it will unicast the Join request.
  Normal/Expected Behavior
Overall Rating: 4.7 (4 ratings)
Correct Answer
Stephen Rodriguez Fri, 09/03/2010 - 10:53
  • Purple, 4500 points or more
u2taz Fri, 09/03/2010 - 11:29
Hi Stephan,
AP doesn't use option 43 even though it is configured. It is always trying to resolve DNS name. Any suggestions?
George Stefanick Fri, 09/03/2010 - 17:12
  • Community Spotlight Award,
    Best Publication, October 2015
You are missing your option 60 ...
Check this link .. If this helps please dont forget to rate the post ...
THANKS
http://www.cisco.com/en/US/docs/wireless/access_point/1130/installation/guide/113h_g.html#wp1008197
Configuring Option 43 for 1100, 1130, 1200, 1240, and 1300 Series Lightweight Access Points
To configure DHCP Option 43 for Cisco Aironet 1100, 1130, 1200, 1240, and 1300 series lightweight access points in the embedded Cisco IOS DHCP server, follow these steps:
Step 1 Enter configuration mode at the Cisco IOS CLI.
Step 2 Create the DHCP pool, including the necessary parameters such as default router and name server. A DHCP scope example is as follows:
ip dhcp pool
network
default-router
dns-server
Where:
 is the name of the DHCP pool, such as AP1240
 is the network IP address where the controller resides, such as 10.0.15.1
 is the subnet mask, such as 255.255.255.0
 is the IP address of the default router, such as 10.0.0.1
 is the IP address of the DNS server, such as 10.0.10.2
Step 3 Add the option 60 line using the following syntax:
option 60 ascii "VCI string"
For the VCI string, use the value from Table G-1. The quotation marks must be included.
Step 4 Add the option 43 line using the following syntax:
option 43 hex <hex string>
The hex string is assembled by concatenating the TLV values shown below:
Type + Length + Value
Type is always f1(hex). Length is the number of controller management IP addresses times 4 in hex. Value is the IP address of the controller listed sequentially in hex.
For example, suppose that there are two controllers with management interface IP addresses, 10.126.126.2 and 10.127.127.2. The type is f1(hex). The length is 2 * 4 = 8 = 08 (hex). The IP addresses translate to 0a7e7e02 and 0a7f7f02. Assembling the string then yields f1080a7e7e020a7f7f02. The resulting Cisco IOS command added to the DHCP scope is listed below:
option 43 hex f1080a7e7e020a7f7f02
Flavio Boniforti Tue, 04/09/2013 - 09:20
Hello George.
As I'm facing the same task with a Fortigate unit, where I need only to put one single WLC, which would the correct option 43 value be?
The WLC IP is 10.30.2.2, which in Hex is 0A1E0202
Now, looking at your explanation, I'm not finding the "length" in the string you typed into your config...
So, how should mine look like?
Kind regards,
F.
George Stefanick Tue, 04/09/2013 - 09:48
So are you trying to add a option 43 for an access point ? The link above should have the full strings for most model aps.
__________________________________________________________________________________________
‎"I'm in a serious relationship with my Wi-Fi. You could say we have a connection."
Stephen Rodriguez Tue, 04/09/2013 - 10:02
option 43 hex f104.0a1e.0202
the f104 is the length. f104 means one WLC f108 would be two.
HTH,
Steve
Please remember to rate useful posts, and mark questions as answered
Related Content
Trending Topics - Security & Network
