Unable to find boot code files for ESW switches.
Answered Question
Sep 2nd, 2010
Since ESW 500 Series firmware version 2.1.16 requires boot version 1.0.0.7 for 8-port ESW models and boot version 1.0.0.4 for 24-port and 48-port models, you may need to manually install or upgrade the boot code to ensure that the appropriate versions are used.
To download firmware and boot code files for ESW switches, go to www.cisco.com/go/esw500help, click the Resources tab, then click the Firmware link. A Cisco.com login is required.
Unable to find boot code at the listed URL.
Correct Answer by Steven DiStefano about 6 years 10 months ago
Thanks Dave.
And remember to use the Browser interface to the switch to install new bootcode. CCA does not do boot code.
Correct Answer by David Hornstein about 6 years 10 months ago
Hi Brian,
I followed the link you mentioned, selected firmware  and rummaged around and found the bootcode.
see my screenshot below.
regards Dave
Overall Rating: 5 (2 ratings)
Correct Answer
David Hornstein Thu, 09/02/2010 - 21:11
  • Gold, 750 points or more
Hi Brian,
regards Dave
Correct Answer
Steven DiStefano Thu, 09/02/2010 - 21:23
  • Blue, 1500 points or more
Thanks Dave.
bmbailey Fri, 09/03/2010 - 05:48
Very odd, there must be a permission setting that prevents me from seeing the boot code.
