Web-auth doesn't load the login.html page
Answered Question
Sep 2nd, 2010
Hello mates.
I have configured a Cisco 2100 WLC. I have configured two WLANs, one of them with Web-Authentication. When I connect to it, I get an IP address, and if I open the browser, I was redirected to the authentication page (in the browser toolbar appears "http://1.1.1.1/login.html", I understand that it works correctly), but doesn't load the page, as if not found (I.E. doesn't find).
I searched the Cisco configuration examples, and in this forum, but haven't found any similar problem.
Any ideas?
Thank you
Correct Answer by kishork_1987 about 6 years 9 months ago
I got it try this
go to virtual interface wich u created 1.1.1.1 in wlc in controller>interfaces>virtual
remove the dns name if any, inside the virtual interface
it will work
Overall Rating: 5 (1 ratings)
kishork_1987 Sat, 09/04/2010 - 02:50
HI,
make sure you dont have any proxy settings on the web browser if so you would not be able to get the login page
Carlos M G Mon, 09/06/2010 - 03:16
Hello
Sorry for not specifying details. I  have no proxy server configured in the browser, I have tested with IE  and Firefox, and with two different computers (With Windows XP and Windows 7)  and I have the same problem, so I think that the problem is in the WLC configuration, but I don't know where,I followed the steps of various manuals and examples of Cisco.
I'm using the internal WLC page for web-authentication, and the "Layout 3 security" is correctly configured in the WLAN.
tahsin.turkdogan Tue, 09/07/2010 - 01:07
Hi;
Check your DNS adress. Make you sure DNS server is working or verify you can reach dns servers.
Carlos M G Tue, 09/07/2010 - 02:56
The WLC is configured to give me as a DNS server, my DNS server on my network, it works correctly, which is in another range of IPs (10.1.1.x), as well as the IP address I assigned the WLC.
Could it be problem of IPs? I have the management interface in the range 172.16.70.x (I have in this range switches and other network appliances, to manage), the dynamic interface I have in the 10.1.1.x range (This is the office general network), and the virtual interface to 1.1.1.1 as has indicated in the manual for Cisco, and the DNS name is "wificontroller".
When the browser is redirect to login page, in the browser toolbar appears the name of the virtual interface ("wificontroller"), but before didn't have a DNS name, and in the browser toolbar appears the IP (1.1.1.1), but I have the same problem. I have the virtual interface configured correctly?
Correct Answer
kishork_1987 Tue, 09/07/2010 - 07:41
I got it try this
it will work
Carlos M G Wed, 09/08/2010 - 01:51
Thanks for you help, I removed the DNS name, and it works correctly. Previously, I tried with this configuration, I suppose that I had some other different configuration. I'm very grateful.
moises.rodriguez Mon, 10/18/2010 - 10:49
I have the same problem, but I already erase the host DNS name from the virtual interface, and the login page does not appear.
If I type 1.1.1.1, I can reach the login page, but it does not load automatically.
Any idea?
Carlos M G Tue, 10/19/2010 - 00:09
When you manually enter the address 1.1.1.1,  can you validate and surf the web?
Check you have the correct DNS and gateway on the clients.
After the problems discussed above, switched WLAN interface with web-auth to use another different range of IPs.
When I did, I again had the same problem (In addition, I had not access to network), and was to have incorrectly DNS and gateway.
Also, in my case, I have a Cisco 3750 switch with different VLAN created, customers will get the 3750 IP as gateway.
Trending Topics - Security & Network
