2 company share 1 network
Sep 3rd, 2010
My company A has a big network with 109 nos (site office) of 3750e and every switches has a 6 vlan. Recently our sister company B submit a proposal & intent to share the network. My question is how to make this happen as we are very concern about the security. I've plan to create a new vlan for company B in every switches but how to restrict the access? Note : both company has own internet access. company A ip is 10.74.x.x and co B 10.1.x.x
tq
Jon Marshall Fri, 09/03/2010 - 02:55
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
tq
Have a read of this recent thread and them come back if you have further questions -
https://supportforums.cisco.com/thread/2039816?tstart=30
I would not recommend having vlans for each company on all your switches. The other company can simply route to your vlans and vice-versa but you do need to think about firewalls.
Jon
Nagaraja Thanthry Fri, 09/03/2010 - 06:10
  • Cisco Employee,
If you do not want Company B to access company A and vice versa, put
access-lists on the core router (router that handles routing between vlans).
The access-list should look like:
access-list 101 deny ip 10.74.0.0 0.0.255.255 10.1.0.0 0.0.255.255
access-list 101 deny ip 10.1.0.0 0.0.255.255 10.74.0.0 0.0.255.255
interface vlan "vlan id"
ip access-group 101 in
exit
This will prevent all communication between Company A vlans and Company B
vlan. If you want specific traffic to flow between them, then you need to
insert those rules before the deny rules.
access-list 101 permit tcp any any eq www
access-list 101 permit tcp any any eq https
access-list 101 permit tcp any eq www any
access-list 101 permit tcp any eq https any
Above configuration allows HTTP and HTTPS traffic between two networks.
Hope this helps.
NT
farozezan73 Sun, 09/26/2010 - 01:37
Tq for your reply. One more thing, the existing network use eigrp protocol. Should I use static route for the new network or eigrp? For info the new network use only 15 routers. tq
