Can I use Catalyst 6504E slot2 for ethernet module or service module?
Answered Question
Sep 3rd, 2010
I am thinking composition of catalyst6504E.
can I use slot2 of catalyst6504E for ethernet module or service module?
cisco configuration tool answer OK.
But cisco power calclator point out me.
configuration tool
     WS-C6504-E
     Catalyst 6500 Enhanced 4-slot chassis,5RU,no PS,no Fan Tray
      S733AEK9-12233SXI
      Cisco CAT6000-SUP720 IOS ADVANCED ENTERPRISE SERVICES SSH
      WS-SUP720-3B
      Catalyst 6500/Cisco 7600 Supervisor 720 Fabric MSFC3 PFC3B
      CF-ADAPTER-SP
      SP adapter for SUP720 and SUP720-10G
      WS-SVC-FWM-1-K9
      Firewall blade for 6500 and 7600, VFW License Separate
      WS-X6748-GE-TX
      Cat6500 48-port 10/100/1000 GE Mod: fabric enabled, RJ-45
      WS-X6724-SFP
      Catalyst 6500 24-port GigE Mod: fabric-enabled (Req. SFPs)
      FAN-MOD-4HS
      High-Speed Fan Module for 7604/6504-E
      PWR-2700-AC/4
      2700W AC Power Supply for Cisco 7604/6504-E
      CAB-7513AC
      AC POWER CORD NORTH AMERICA (110V)
SlotLine CardOutput Current(@42V)
(A)
Output Power
(W)
Typical Power Used
(W)
Heat Dissipation
(BTU/Hr)
FAN2FAN-MOD-4HS1.4360.0648.05241.30
1WS-SUP720-3B6.72282.24225.791133.94
2WS-SVC-FWM-16.72282.24225.791133.94
3WS-X6724-SFP4.93207.06165.65831.89
4WS-X6148A-GE-TX2.50105.0084.00421.85
(A)
Output Power
(W)
Typical Power Used
(W)
Heat Dissipation
(BTU/Hr)
Total22.30936.60749.283762.93
Slot 2 is redundant supervisor-engine slot. It will allocate either the power of a supervisor engine or of the line card, whichever is greater. The Actual Output Current, Out Power and Heat Dissipation for your selected line card are 4.09A,171.78W,and 690.15 BTU/Hr
Correct Answer by Jon Marshall about 6 years 8 months ago
As pointed out by Francisco you can use redudant slot for any module you like.
Jon
Correct Answer by francisco_1 about 6 years 8 months ago
According to the table above and as Jon stated yes you can.
Francisco
Jon Marshall Fri, 09/03/2010 - 03:07
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
Not sure what you are asking. Both your outputs show that you can indeed use slot 2 for any module you want.
Perhaps you could clarify.
Jon
iotoiotoioto Fri, 09/03/2010 - 03:39
thanks, Jon.
sorry, I just saw "Slot 2 is redundant supervisor-engine slot. "
and my colleague say it's impossible.
so I asked.
did anyone use that composition?
francisco_1 Fri, 09/03/2010 - 03:43
  • Gold, 750 points or more
Chassis
Supervisor Engine 32/ Supervisor Engine 720 Slots
Classic Line-Card Slots
Single Fabric Connected Line Cards
Dual Fabric Connected Line Cards
Cisco Catalyst 6503
1 and 2
2 and 3
2 and 3
WS-X67XX line cards not supported
Cisco Catalyst 6503-E
1 and 2
2 and 3
2 and 3
2 and 3
Cisco Catalyst 6504-E
1 and 2
2 thru 4
2 thru 4
2 thru 4
Cisco Catalyst 6506
5 and 6
1 through 6
1 through 6
1 through 6
Cisco Catalyst 6506-E
5 and 6
1 through 6
1 through 6
1 through 6
Cisco Catalyst 6509
5 and 6
1 through 9
1 through 9
1 through 9
Cisco Catalyst 6509-E
5 and 6
1 through 9
1 through 9
1 through 9
Cisco Catalyst 6509-NEB
5 and 6
1 through 9
1 through 9
1 through 9
Cisco Catalyst 6509-NEB-A
5 and 6
1 through 9
1 through 9
1 through 9
Cisco Catalyst 6513
7 and 8
1 through 13
1 through 13
9 through 13
Correct Answer
francisco_1 Fri, 09/03/2010 - 03:44
Francisco
Correct Answer
Jon Marshall Fri, 09/03/2010 - 03:47
  • Hall of Fame,
    Founding Member
    2017 LAN, WAN
Jon
