CSM duplicate device when I try to add a new one with contexts
Sep 3rd, 2010
Hi guys
I got a problem right now, I'm using CSM v3.3.0 and I'm trying to delete a device with single context and add the same device with multiple context, we made an upgrade of the ASA and now it had 2 contexts, but when the CSM is discovering the device at the end of the process it says:
"The following security context devices could not be added to inventory due to duplicate names: "
but I'm trying to find the other context devices and I just can't find them, i made the same operation off delete/add and it keep saying the same thing.
So if anyone got any idea how to find the other context devices that will be great.
Regards.
Panos Kampanakis Fri, 09/03/2010 - 09:23
  • Cisco Employee,
The context you had probably was not deleted from the DCR database. Can you check that?
I hope it helps.
PK
Luis Carranza Fri, 09/03/2010 - 09:30
Thanks for the answer, can you help how to find the DCR database in the CSM please
Panos Kampanakis Fri, 09/03/2010 - 09:58
  • Cisco Employee,
You should open the server page (not CSM client) and it should be under the Device and Credentials and Device Management.
I hope it helps.
PK
Luis Carranza Fri, 09/03/2010 - 10:01
in fact I already there but I don't know if it's right or not because I don't see any device on the list. I think I should start a Discovery don't you think?
Related Content
