3750x stacked switches ios upgrade
Answered Question
Sep 3rd, 2010
Hello I am looking for the documentation on upgrading the IOS image on two 3750X switchstack, is it the same process as a 3750 switchstack? I found this link but just want to make sure it applies to the 3750-X model too:
http://www.cisco.com/en/US/products/hw/switches/ps5023/products_configuration_example09186a00804799d7.shtml
Correct Answer by Reza Sharifi about 6 years 7 months ago
Brian,
Upgrade path should be the same since you can have a mix all different type of 3750s together to build a stack.
Here is also a good document:
http://www.ciscosistemi.net/en/US/docs/switches/lan/catalyst3750e_3560e/software/release/12.2_55_se/configuration/guide/swstack.pdf
Reza
Overall Rating: 5 (1 ratings)
Correct Answer
Reza Sharifi Fri, 09/03/2010 - 11:46
  • Cisco Designated VIP,
    2017 LAN
Brian,
Reza
Leo Laohoo Fri, 09/03/2010 - 21:05
  • Hall of Fame,
    The Hall of Fame designation is a lifetime achievement award based on significant overall achievements in the community.
    2017 LAN, Wireless
You can also upgrade and BOOT the IOS via a USB stick.
