BGP multihomed 2 ISPs, One won't run BGP
Sep 3rd, 2010
Hi all!
We currently have several links (XDSL) to one provider with static routes and several IP blocks provided. We are getting an E10 from a different provider ; we are planning on getting our own address space and running BGP. The first provider won't run BGP...
I was wondering if by adding a router between the first provider and us, I could somewhat resolve the issue:
     - Static routes on provider side
     - BGP on our side with private ASN
Is this feasible ? Any drawbacks to that method?
Thank you all!
shivlu jain Sat, 09/04/2010 - 05:11
In this case, one issue could come across about the different outgoing and incoming interfaces. If you own your own address space(minimum /24 pool) in that case static SP need to advertise that pool, so while traffic comes form internet might have two but for outgoing traffic from your cloud might have one path.
regards
Shivlu Jain
http://www.mplsvpn.info
