[ASK] Disabled in backup interface???
Sep 3rd, 2010
I have a problem in configuring two pair of backup interface on my customer's router (3845). It's ok when I configure just one of them. If I configure both pairs of interfaces into backup interface, one of them will be in disabled mode, as shown below :
WANR01#sh ip int bri
Interface                       IP-Address                OK?    Method   Status                             Protocol
GigabitEthernet0/0         172.16.199.106       YES      NVRAM  up                                   up
GigabitEthernet0/1         172.16.3.5              YES      NVRAM  up                                   up
Serial0/0/0                     unassigned            YES      NVRAM  administratively down        down
Serial0/0/1                     unassigned            YES      NVRAM  administratively down        down
FastEthernet0/1/0          125.213.133.186      YES     NVRAM  standby mode                  down
FastEthernet0/2/0          172.112.22.6           YES     NVRAM  standby mode/disabled  down
FastEthernet0/2/1          123.231.177.238      YES     NVRAM  up                                   up
Loopback0                    172.16.199.12          YES     NVRAM  up                                   up
WANR01#sh backup
Primary Interface   Secondary Interface   Status
GigabitEthernet0/1  FastEthernet0/2/0     disabled
FastEthernet0/2/1   FastEthernet0/1/0     normal operation
Does anybody have a clue to solve this problem?
Julio Carvajal Tue, 03/19/2013 - 00:13
  • Purple, 4500 points or more
Hello Peter,
I was just working on a GNS3 lab for the CCIE R&S and got into a task where I should use this kind of Setup redundant interfaces and got the same result ( Got the disabled state).. In my case was because the primary interface was administrative shutdown.
Seems like when this happens the default action is to put the standby interface in shutdown state and it does not matter how many times you get into the backup interface and do a no shut... It will stay on that particular state
I would say that is expected as this works by monitoring the protocol line, not if I have shut it down or not...
Anyway just wanted to share that with anyone else having the same issue, looks like I have hit a wall as it does not matter if I take down the physical link the interface will keep as up. so GNS bug
Julio Carvajal
paul driver Tue, 03/19/2013 - 02:04
  • Green, 3000 points or more
All,
Just to confirm what Julio/Peter has stated, just tested this on 2811 routers with 12.4T IOS
R1#sh backup
FastEthernet0/0     FastEthernet0/1       normal operation
Serial0/2/0         Serial0/3/0           normal operation
R1(config)#int ser0/2/0
R1(config-if)#shut
R1#sh backup
Serial0/2/0         Serial0/3/0           disabled
res
Paul
Please don't forget to rate any posts that have been helpful.
Thanks.
Peter Paluch Wed, 03/20/2013 - 17:21
  • Cisco Employee,
Julio and Paul,
I have also re-tested the backup interface feature on a 2691 router IOS. It seems that I have been too hasty in my first answer in this thread. Julio, you have been very kind to mark that answer as Cisco Endorsed but it does not really deserve the rating as it is misleading. I am not sure if you are able to un-mark that designation - if not, I will delete the entire response as it is wrong.
In any case, these are my findings:
  • If the main interface is up,up, the backup interface will be put into standby,down mode.
  • If the main interface is up,down or down,down, the backup interface will be put into up,up mode.
  • If the main interface is administratively down,down, the backup interface will be put into standby/disabled,down
  • It is not possible to manipulate the state of the backup interface using the shutdown or no shutdown command. This setting will always be carried over from the main interface.
The last point in particular shows that my former assessment of the situation was wrong. It would not be possible to deactivate the Fa0/2/0 interface as I originally suggested.
So this leaves me puzzled. A backup interface is in disabled state only if the main interface is shutdown. However, the OP's post shows that the main interface Gi0/1 is up,up while the backup interface Fa0/2/0 is disabled. This is clearly not logical. An IOS bug, perhaps?
Best regards,
Peter
Julio Carvajal Wed, 03/20/2013 - 23:43
Hello Peter,
No, there is no way to unmark it,
I got confused with your post Paul lol, I read that you were refiring to the no shut on the pimary interface not the backup one
I would say that if you want we can delete both your answer and mine so we can start from scratch but yes I do agree with you
                STATUS                                                       Protocol
Primary      UP                          UP
Secondary                    Standby mode          Down
Primary                                    Admin down                              Down
Secondary   Standby Disabled    Down
Even if you try to manually do a no shut on secondary or backup interface  it will not come up,
Why?
Because as soon as you configure on the main interface that "x" interface will be backup the status of that interface will depend on the main interface state
ravi rajani Wed, 04/24/2013 - 22:37
If we manually shutdown the primary interface, backup interface will go to disabled.
To work it properly, i changed the (serial interface) encapsulation to ppp (other end = hdlc), so for primary interface only protocal went down and backup link became up with below deb logs -
R1(config)#int s1/0
R1(config-if)#enc
R1(config-if)#encapsulation ppp
R1(config-if)#end
R1#
R1#
*Mar  1 00:14:27.551: %SYS-5-CONFIG_I: Configured from console by console
R1#
*Mar  1 00:14:27.723: BACKUP(Serial1/0): event = primary interface went down
*Mar  1 00:14:27.727: BACKUP(Serial1/0): changed state to "waiting to backup"
*Mar  1 00:14:28.719: %LINEPROTO-5-UPDOWN: Line protocol on Interface Serial1/0, changed state to down
R1#
*Mar  1 00:14:28.719: BACKUP(Serial1/0): event = primary interface went down
R1#
*Mar  1 00:14:30.727: BACKUP(Serial1/0): event = timer expired on primary
*Mar  1 00:14:30.731: BACKUP(Serial1/0): secondary interface (Serial1/1) made active
*Mar  1 00:14:30.731: BACKUP(Serial1/0): changed state to "backup mode"
R1#
*Mar  1 00:14:32.727: %LINK-3-UPDOWN: Interface Serial1/1, changed state to up
R1#
*Mar  1 00:14:32.735: BACKUP(Serial1/1): event = secondary interface came up
*Mar  1 00:14:33.731: %LINEPROTO-5-UPDOWN: Line protocol on Interface Serial1/1, changed state to up
R1#
*Mar  1 00:14:33.731: BACKUP(Serial1/1): event = secondary interface came up
R1#
R1#
R1#
R1#
R1#sh ip int brie
FastEthernet0/0            unassigned      YES unset  administratively down down
FastEthernet0/1            unassigned      YES unset  administratively down down
Serial1/0                  12.0.0.1        YES manual up                    down
Serial1/1                  120.0.0.1       YES manual up                    up
Serial1/2                  unassigned      YES unset  administratively down down
Serial1/3                  unassigned      YES unset  administratively down down
