rme 4.3.1 sql patch
Sep 3rd, 2010
I am trying to complete a new install of lms 3.2. I am to the point where I am applying the specific patches into rme.
I am having a problem with CSCth05448.
I have followed the instructions contained in the zip file. When I paste the contents and hit the execute button, it looks
like everything works fine. But at the bottom of the page I get:
syntax error near 'create' on line 37 (DBD: prepare failed).
Anybody run into this problem? Have you been able to successfully apply this patch?
Any help is appreciated. Thanks - chris
Overall Rating: 5 (1 ratings)
Joel Monge Fri, 09/03/2010 - 12:40
  • Cisco Employee,
The problem is a missing ";" after the create statements.  Since this involves database handling, you should get in touch with TAC to walk you through it.
cmarva Tue, 09/07/2010 - 04:27
thanks for the help. I copied and edited the original file, added the sems, and the tables were created just fine.
thanks again, I appreciate it - chris
