Is there a way to edit the saved StartCfg.cfg file on a Linksys SRW switch?
Sep 3rd, 2010
I have a SRW248G4 switch that I want to edit the StartCfg.cfg file to use as a template for several new switches.  The content of the startcfg.cfg file looks to be binary or mostly binary.  Is there a way to get the switch to save and load the file in text format similar to the Cisco switches?
An alternate option is to create a templete config on one of the new switches with all the standard settings, save it, upload that template config to the other new switches and change the things that are different/unique from the web interface.  This is possible but will take a lot longer.
Kerry Melcher, CCNP
