1310 Bridge with wireless clients configuration
Sep 3rd, 2010
I have a 871W router at the main building and a 1310 in a remote building. The 1310 is currently acting as a "repeater" which gives us a connection back to the main building as well as access for wireless clients near the 1310. I now have a need for both wireless and wired clients near the 1310. To do this I placed the 1310 in the "non-root bridge wirless-client" role. This allowed my wireless clients to connect to the 1310 and reach the main building. The wired clients however cannot reach anything. They do not even pick up a DHCP address. I manually assigned an IP address on a wired client and it could ping the 1310 but nothing beyond the 1310.
Is there a different role I should have set on this radio? I've also tried 3 different versions of IOS, eaching giving me different results. In an older version of IOS this mode would not even let the clients connect wirelessly to the 1310. Since I received different results on each version of IOS I'm not getting a good feeling about this 1310.
Brandon
Below is the configuration of the 1310
service password-encryption
hostname XXXX-1300
enable secret xxxxxxxxxxxxxxxxxxxxxx
no aaa new-model
dot11 syslog
dot11 ssid xxxxwlan
   authentication open
   authentication key-management wpa
   infrastructure-ssid
   wpa-psk ascii xxxxxxxxxxxxxxxxxxxxxxxxx
bridge irb
interface Dot11Radio0
no ip address
no ip route-cache
encryption mode ciphers tkip
ssid xxxxxwlan
station-role non-root bridge wireless-clients
infrastructure-client
bridge-group 1
bridge-group 1 subscriber-loop-control
bridge-group 1 block-unknown-source
no bridge-group 1 source-learning
no bridge-group 1 unicast-flooding
bridge-group 1 spanning-disabled
interface FastEthernet0
no ip address
no ip route-cache
bridge-group 1
interface BVI1
ip address 192.168.1.2 255.255.255.0
no ip route-cache
ip http server
no ip http secure-server
ip http help-path http://www.cisco.com/warp/public/779/smbiz/prodconfig/help/eag
bridge 1 route ip
line con 0
transport output all
line vty 0 4
login local
transport input all
line vty 5 15
login
transport input all
end
Stephen Rodriguez Wed, 09/08/2010 - 06:24
  • Purple, 4500 points or more
what VLAN are the wired clients in?  If they are not in the 192.168.2.x subnet, you'll need to trunk across the 1310 to the 871/
bhatok Wed, 09/08/2010 - 06:27
They are in the 192.168.1.x vlan with the wireless clients. This is a small network so everything is in a single vlan.
Brandon
iswanizan Mon, 01/31/2011 - 02:51
Today i faced 1 problem, Im doing the outdoor wireless. 1st stage, im using 1 unit AP1310 as a RootAP and client also using AP1310 as a WGB. and have 2 client wired (PLC and PC connect together with AP1310 in 1 switch inside 1 cabin)..Everthing works fine and i can remote is from any company network.
2nd stage (upgrade), my company want to replace RootAP 1310 to Mesh Network with 1 RAP using LWAPP1522 and WLC4400. After configure everything to WLC, i only can remote my AP1310 only and cant remote my PLC and PC as normal. I also cant ping my gateway from PC using AP1310 to network. From the WLC Client, i only can see AP1310 (bridge) the client of bridge not appear. Why ya?
Please help.
Note:
PLC= Programable Logic Control
PC= Cabin Computer
Trending Topics: Other Wireless Mobility
client could not be authenticated
Network Analysis Module (NAM) Products
Cisco 6500 nam
reason 440 driver failure
Cisco password cracker
Cisco Wireless mode
