SPA504G: Message waiting indicator active after reset?
fedelhaeuser
Our SPA504G phones are provisioned to receive MWI from our SIP provider. For the most part MWI works fine, except the red light is on and a little envelope is shown next to the extension key every time the phone reboots - voice mail pending or not. How can we determine if our service provider indicates MWI or if the phone invents its MW indication? Are there any configuration options besides Message_Waiting_N_ and Mailbox_ID_N_ to control the behavior of the MWI?
Alberto Montilla
Dear Sir;
Please get a network trace. Depending on the SP, the MWI may come differently depending on the messaging used. Get the traces and send it over so that I can check whether the network is indicating any pending message.
regards
Alberto
Alberto Montilla
Dear Sir;
regards
Alberto
Hi Alberto,
I sent you a PM with a log. Appreciate your help.
Frank
fedelhaeuser
Think I found out myself what was caused the problem: I had Message_Waiting_N_ set to Yes.
Frank
