Optimized Edge Routing in IOS Ver15.0
Answered Question
Sep 3rd, 2010
hi,
what is the license required for  the OER feature in IOS 15.0 ? already used http://www.cisco.com/go/fn, to confirm the feature is present, but there is no information on the license requirements.
Best Regards,
Correct Answer by Lei Tian about 6 years 10 months ago
Hi Nuno,
Check the output of show version, you need to have license for data package. If not, you can active the evaluation license to test it.
http://www.cisco.com/en/US/docs/routers/access/sw_activation/SA_on_ISR.html#wp1097675
Hope that helps.
Lei Tian
Overall Rating: 5 (1 ratings)
Nuno Melo Sat, 09/04/2010 - 03:00
Thanks Vijay for the quick response. I  had already took a look at the feature roadmap, and concluded that it was present in IOS.15, however the comand "oer master" is not available in the router so i am assuming that some license is missing, what i cannot find is information about what license is required for this.
Best Regards,
Nuno Melo Wed, 09/08/2010 - 08:06
Hello Lei Tai,
This solved the problem, for activation of OER feature the datak9 license is needed.
