Jennifer Halim Sat, 09/04/2010 - 04:54
Yes it is possible
Here it is for your example:
object network test
   host 1.1.1.1
   nat (inside,outside) static 1.1.1.1 service tcp 80 8080
s.nicholls Sat, 09/04/2010 - 11:44
I tried this and I get back this error message in the logs ASA-5-305013
Asymmetric NAT rules matched for forward and reverse flows; Connection for tcp src Outside:94.14.239.49/11199 dst SF1-Interface:109.74.241.215/80 denied due to NAT reverse path failure
Kureli Sankar Sun, 09/05/2010 - 18:43
If you inside server is listening on 8080 then the example should be like this.
object network test
   host 1.1.1.1
   nat (inside,outside) static 1.1.1.1 service tcp 8080 80
Follow this link: https://supportforums.cisco.com/docs/DOC-9129
Regarding the syslog that you are seeing you can refer this link: https://supportforums.cisco.com/docs/DOC-12569
Pls. collect the output of the following:
  packet-tracer input Outside tcp 94.14.239.49 11199 109.74.241.215 80 det
  packet-tracer input SF1-Interface tcp 109.74.241.215 80 94.14.239.49 11199  det
See the section towards the end where it says dropped and check the reason and the nat line that it is matching.
Post the output if you have questions.
-KS
