Direct connection between IP Phones and Teleco?
Sep 4th, 2010
While examining my new 7941 IP Phone, I noticed that there is a lable that mentioned that 79xx can be connected to Telco?
Is this right to connect the ip phone directly to PSTN ?!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Thanks a lot.
William Bell Sat, 09/04/2010 - 07:45
If you mean can you connect the phone directly to a POTS line then the
answer is no. I am guessing that if you are looking at a port it would be
the "Aux" port. This port is meant to be used for connecting an expansion
module. Of course the 7941 does support the expansion module but that is
probably a manufacturing thing.
HTH.
Bill
Please remember to rate helpful posts.
On 9/4/10 10:21 AM, "AhmedBassiony"
