Disable cellular signal (¿ SSID ?)
Sep 4th, 2010
We have the Cisco Cellular CDMA and GSM modules installed in our 881G routers.
Everything works VERY well and 3G is suppppper fast.
However, I would like to somehow disable the advertisement of my radio module to other subscribers on the provider network.
Also when I "show users", I am seeing the PPP connection and Verizon tells me to disable SSID to remove the PPP connection.
881G router# sh users
Line User       Host(s)          Idle          Location
*0   Con 0      BR549 idle       00:00:00
3   tty  3     Async interface  00:00:01      PPP: public ip address
EX Verizon tech support insists I should disable the SSID.
I understand wireless 802.11 SSID but cannot locate ANYTHING on SSID for CDMA or GSM cellular.
ANYONE have any idea(s)?
As always, I "WE" appreciate the assistance.
If requested, I can post the actual config making this cellular card operational.
Frank
