Cisco 871 and C2960 routing between vlans.
Answered Question
I have an 871 wireless router (c870-advipservicesk9-m version 15.1) and the c2960 switch (c2960-lanbasek9-m version 12.2). I was wondering if i can use the 871 to route between vlans on the c2960. I need to have 7 vlans setup on the network but the 871 only supports 4 vlans in its database. I know I can create more than 4 vlans on c2960's database but I don't how or if it's even possible to route between those vlans using the 871.
Correct Answer by Leo Laohoo about 6 years 8 months ago
Hi Lei,
Just tried IOS versions 12.4(15)XY5, 12.4(11)XW10, and 12.4(4)XC7 and all three 12.4 will support 2 VLANs.
It looks like only 12.3 will support 10 VLANs.  Too bad.
Correct Answer by Nagaraja Thanthry about 6 years 8 months ago
Hello Lei,
871 supports 10 Wireless VLANs (10 BVI interfaces) but it has limitation of
4 VLANs (Ethernet based vlan).
http://www.cisco.com/en/US/prod/collateral/routers/ps380/ps6200/product_...
_sheet0900aecd8028a976.html
The router will not accept the configuration of 5th VLAN.
NT
Overall Rating: 5 (8 ratings)
Reza Sharifi Sat, 09/04/2010 - 14:50
  • Cisco Designated VIP,
    2017 LAN
According to the datasheet, 871 supports OSPF, BGP and EIGRP.  I don't see why you can't route between 4 vlans using sub-interfaces with 802.1q trunk.
Reza
Reza Sharifi Sat, 09/04/2010 - 15:08
    2017 LAN
Well, the limitation on the router is only 4 vlans, so even though you set up 7 on the switch the router does not support more than 4.
what happens when you try to creat the 5 vlan on the router?  are you using 1 port with 802.1q and sub-interfaces?
Leo Laohoo Sun, 09/05/2010 - 15:19
  • Hall of Fame,
    The Hall of Fame designation is a lifetime achievement award based on significant overall achievements in the community.
    2017 LAN, Wireless
I hate to be the person to deliver bad news but 870 ISR will only support TWO (2) VLANs and VLAN 1, the default, is already one of them.
Lei Tian Sun, 09/05/2010 - 16:09
  • Cisco Employee,
You can downgrade your code. Tried 12.3(8)-YI2, it supports max 10 Vlans. Not sure the 4 Vlan limitation starts from which release, but I guess 12.4 none T release should support 10 Vlans as well.
Check the supported features before you change the code.
Lei Tian
Lei Tian Sun, 09/05/2010 - 16:45
  • Cisco Employee,
Hi NT,
I understand the limitation. I think that was added in 12.4T train. It supports max 10 Vlans before 12.4T.
Lei Tian
Nagaraja Thanthry Sun, 09/05/2010 - 17:45
  • Cisco Employee,
Hello Lei,
Have you personally configured 10 VLANs on this hardware? I tried on couple
of devices but after 4 vlans, it gave error message. If you have actually
tested it, can you please post the corresponding outputs here? Also, what
version/feature set you are running?
NT
Leo Laohoo Sun, 09/05/2010 - 17:27
  • Hall of Fame,
    2017 LAN, Wireless
Support for 2 VLANs with Base Image. One VLAN dedicated to DMZ.
Lei Tian Sun, 09/05/2010 - 17:46
  • Cisco Employee,
For the record, I tested on my 871. Here is the output.
R2#sh ver
Cisco IOS Software, C870 Software (C870-ADVIPSERVICESK9-M), Version 12.3(8)YI2, RELEASE SOFTWARE (fc1)
Synched to technology version 12.3(10.3)T2
Copyright (c) 1986-2005 by Cisco Systems, Inc.
Compiled Tue 14-Jun-05 18:58 by ealyon
ROM: System Bootstrap, Version 12.3(8r)YI4, RELEASE SOFTWARE
ROM: Cisco IOS Software, C870 Software (C870-ADVIPSERVICESK9-M), Version 12.3(8)YI2, RELEASE SOFTWARE (fc1)
R2 uptime is 1 minute
System image file is "flash:c870-advipservicesk9-mz.123-8.YI2.bin"
A summary of U.S. laws governing Cisco cryptographic products may be found at:
[email protected].
Cisco 871W (MPC8272) processor (revision 0x200) with 118784K/12288K bytes of memory.
Processor board ID FCZ114561YX
MPC8272 CPU Rev: Part Number 0xC, Mask Number 0x10
5 FastEthernet interfaces
1 802.11 Radio
128K bytes of non-volatile configuration memory.
24576K bytes of processor board System flash (Intel Strataflash)
R2#sh int trunk
Port      Mode         Encapsulation  Status        Native vlan
Fa0       on           802.1q         trunking      1
Port      Vlans allowed on trunk
Fa0       1-1005
Port      Vlans allowed and active in management domain
Fa0       1,10,20,30,40,50,60,70,80,90
Port      Vlans in spanning tree forwarding state and not pruned
R2#sh ip int b | ex un
Interface                  IP-Address      OK? Method Status                Protocol
FastEthernet4              192.168.1.1     YES NVRAM  up                    down
Vlan1                      10.10.10.1      YES NVRAM  up                    up
Vlan10                     10.10.0.1       YES NVRAM  up                    up
Vlan20                     10.10.20.1      YES NVRAM  up                    up
Vlan30                     10.10.30.1      YES NVRAM  up                    up
Vlan40                     10.10.40.1      YES NVRAM  up                    up
Vlan50                     10.10.50.1      YES NVRAM  up                    up
Vlan60                     10.10.60.1      YES NVRAM  up                    up
Vlan70                     10.10.70.1      YES NVRAM  up                    up
Vlan80                     10.10.80.1      YES NVRAM  up                    up
Vlan90                     10.10.90.1      YES NVRAM  up                    up
Lei Tian
Leo Laohoo Sun, 09/05/2010 - 18:14
  • Hall of Fame,
    2017 LAN, Wireless
Nice one Lei (+5) here too.
This is one of those "murky" ones.
Let me get this straight, if you use, say 12.4 can you get 10 VLAN support?   What I meant to ask is, is the "T" train causing the number of VLANs supported to be lowered?   ANd if I use, for example, 12.2(24), I can get 10 VLANs?
Lei Tian Sun, 09/05/2010 - 18:21
  • Cisco Employee,
Thanks for the rating
Definitely not in 12.4T; I think might be support for 12.4.
Leo Laohoo Sun, 09/05/2010 - 18:38
  • Hall of Fame,
    2017 LAN, Wireless
Thanks for that.
Correct Answer
Leo Laohoo Sun, 09/05/2010 - 19:49
  • Hall of Fame,
    2017 LAN, Wireless
Hi Lei,
Lei Tian Sun, 09/05/2010 - 20:02
  • Cisco Employee,
Hi Leo,
Thanks for testing it out!
Leo Laohoo Sun, 09/05/2010 - 20:49
  • Hall of Fame,
    2017 LAN, Wireless
Thanks Lei.
Related Content
