LMS 3.2: DCR Server Down
Sep 5th, 2010
I have LMS 3.2 installed on a Multi-CPU server (DXDiag is attached), but currently only 1 CPU is active.
I have few issues with LMS:
1. If i click on Process it takes too much time to show up.
2. From CLI if i do "pdshow" it also takes a long time (more than 10 minutes)
3. Device Discovery is failed as i am getting an error message "DCR Service is Down" (attached the error message for your referecne)
4. Device & Credential is also showing failed.
Kindly suggest...
Joe Clarke Sun, 09/05/2010 - 09:45
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
You have a process failure.  You need to wait for pdshow to complete, then post that output.  This can take up to 45 minutes.
Joe Clarke Mon, 09/06/2010 - 10:04
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
Post the TomcatMonitor.log and NMSROOT/MDC/tomcat/logs/stdout.log and stderr.log.
acharyr123 Tue, 09/07/2010 - 01:15
HI Clarke,
Server hostname was changed after installing LMS. Do you think this is causing this problem?
Partha
Joe Clarke Tue, 09/07/2010 - 21:24
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
Yes.  You will need to run the NMSROOT/bin/hostnamechange.pl script to correct the hostname within LMS:
NMSROOT/bin/perl NMSROOT/bin/hostnamechange.pl
